Question about Monarch Office Equipment & Supplies
Need to know how to change the vertical error 020
    Scholar:
  • 148 Answers
Vertical magnification must be 1 to 7 or 4 to 250 for the scalable or downloaded TrueType fonts.
Posted on Sep 16, 2008
Error 020
Error 020 means its a problem with the main board(hardware) on the printer. you should contact printer manufacturer.
***If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 19, 2013 | OKI B4350 Laser Printer
Toshiba TP48D90 Convergence
391-020 will not cross,,, if it was the last numbers that change it would.
http://www.shopjimmy.com/
Sep 04, 2012 | Toshiba Televison & Video
Error code E000020-03b0
This is the error code indicating a problem with the Cyan drum - drum is coming to an end. The 020 is for the drum or developer. The 03 is for cyan and the BO is for drum life. Chang ethe drum out and all should be good.
Sep 15, 2011 | Canon imageRUNNER C3200 Copier
My RISO MZ770E gives error code "T17-020" Any Help would be appreciated
Error T17-020 means: The solenoid counter is not connected.
Hints: Check connection. Reconnect. Change counter.
Feb 17, 2011 | Riso RZ220 Duplicator
Fatal error 020: oki c5450
As far as 020 error is concerned it is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Aug 18, 2010 | OKI C5400 Laser Printer
I just changed the toner and I now have an error code 020
020 is a CU rom error... check that your memory and PS cards are fitted into the main PCB properly, if not remove the PS card and try it. Beyond that you might have a faulty main board
Sep 08, 2009 | OKI B4350 Laser Printer
Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
Xanté Ilumina: 020 fatal error
unplug power. open rear panel (2 thumb screws) check fitting of the ROM chips, restart..
020 relates to Slot A ROM DIMM
May need new ROM, or that CU PCB if unsuccesful
Jul 21, 2008 | Xante Ilumina Digital Color Press Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Dec 01, 2007 | OKI C5300n Led Printer
48 people viewed this question
Top Monarch Office Equipment & Supplies Experts
David Payne
David Payne
ka4iup
ka4iup
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
