Can not get fi fi on my tx even though I have been getting it for a year
  • 19 more comments
  • billegel Sep 16, 2008
    my palm pilot is a t/x. It was working fine until my Verizon modum went bad and they replaced it...big struggle to install and my palm cannot recognize the new address
    bill egel
    I HAVE NOT GOTTEN ANY COMMENTS ON MY WI-FI PROBLEM; HAVE NOT BEEN ABLE TO GET WI-FI SINCE VERIZON INSTALLED NEW MOD....IT TOOK LONG TIME AND NOW MY PALM PILOTS(2) can not pick up wi-fi..can anyone offer help?bill egel
    as stated, I have a Palm Pilot T/X...when I try to get on the web it says that it is initializing..obtaining IP address....then it says page you requested can not be displayed...Maybe URL YOU ENTERED CANNOT BE RESOLVED. i HAVE NOT TRIED ANYTHING-IT WON'T LET ME.
    BILL EGEL
    HOW DO i MAKE CERTAIN THAT THE NETWORK CONNECTIONS ARE CORRECT AND WHERE DO I FIND THE CORRECT SECURITY KEY?
    billegel
    THIS LOOKS LIKE IT MIGHT WORK AND i can get into systems, but i see no way to get into palm os devices......i have been fighting this problem for 24 hours...really discouraged.
    billegel
    I AM BACK WHERE I WAS 24 HOURS AGO
    billegel
    still can not get WI Fi on my Palm T/X since Verizon changed mod. Palm can not read wi fi signal
    billegel
  • billegel Sep 17, 2008
    IT IS NOW 9/17/08 AND I NAM STILL LOOKING FOR HELP THAT WOULD ENABLE ME TO GET GET WI-FI ON PALM PILOT T/X. USED TO GET IT, BUT EVER SINCE MY VERIZON MOD. WAS REPLACED MY PALM CAN NOT TALK TO MY LAPTOP. ANY HELP WOULD BE APPRECIATED.
    BILLEGEL
    MY WI-FI MODEMIS A WESTELL MODEL A90-750015-07. IT IS CALLED A "7500" model and it was installed on 9/15/08 after they struggled and changed my wi-fi name. wi-fi used to work anywhere in my home.
    billegel
    turned modem and 2 palm pilots off for ten minutes; turned both on---one listed serveralsited but could not click onto any of them. the other palm pilot said.."system error:timeout. The server is not responding (0 x 1212).2
    billegel
    still no progress and no suggestions for 3 hours-what now?
    billegel
    i can scan about 10 different networks incuding the one i used to use and the one i am now supposed to use; they are are listed, i have attempted to connect with the close ones-it acts like it is initializing and then fails.
    billegel
    more info about not getting a wi-fi signal at home on my palm pilot....I went to a coffee shop that had wi-fi and found that both of my palm pilots fired up right away-no problem. So the problem is with the Verizon moden or in the way that it was installed for me. I called Verizon again (3rd time). They could not help even though they created the problem!!!! I have had wi-fi everywhere in my for more than a year. What can I try next???
  • billegel Sep 18, 2008
    still hoping that some one can help.
    billegel
    I HAVE BEEN TRYING TO GET HELP WITH THIS-TO NO AVAIL. SINCE VERIZON INSTALLED A NEW MODEM (WITH GREAT DIFFICULTY) A COUPLE OF DAYS AGO, THE WI-FI LIGHT IS LIT, BUT I AM NOT GETTING WI-FI ON MY PALM PILOT T/X. I WENT TO A COFFE SHOP THAT HAD WI-FI AND MY PALM PILOT WORKed QUICKLY AND PERFECTLY. VERIZON DOES NOT WANT TO HELP WITH THIS PROBLEM, BUT I AM PAYING FOR WI-FI IN MY HOUSE BUT NOT RECEIVING IT!
    I THINK THAT THIS STRATEGY MIGHT WORK AND I CAN GO TO SYSTEMS, BUT I DO NOT SEE PALM OS DEVICES ANYWHERE SO I AM STUCK ON THE SECOND STEP; I HAVE HIT A BRICK WALL.
    billegel
  • billegel Sep 20, 2008
    Nothing suggested has worked and I am not getting any more suggestions. Guess that there are no experts out there. All I know is that it worked fine before Verizon installed a new modem!!!!
    billegel
  • 2,794 Answers
Make sure the wi fi is turned on.
Turn the bluetooth off.
Press the network icon on the bottom of the TX.
Select scan for networks.
Anything with a lock next to the network name requires a wep password to get in.
If you are trying to get onto a secured network and weren't successful, go to palm.com and get the software update for wireless networking on your TX.
Posted on Sep 18, 2008
  • Tim Babcock
    Tim Babcock Sep 18, 2008
    Whats the make and model of the router you are using on your modem?
  • 928 Answers
Please give more information such as the brand and model of your wifi modem. We cannot give suggestinos on fixing the problem unless we have more information.
Posted on Sep 16, 2008
  • 2 more comments
  • Thomas Lim
    Thomas Lim Sep 17, 2008
    Ok thank you for the information.
    What you need to do is to find out the wireless name and security of your westell. You can do this by calling up your provider and asking for the information. I ask this because they change the password for the westell so best ask them for the info.
    Next you have to connect to the new name on your PDA. You can do this by viewing the available wireless network and connecting to the new name with the security key that you will get from your provider.
  • Thomas Lim
    If that is the case then that means that some of them are just saved on there. Remove the ones that you do not know about its possible they are just chached on your computer. Did you already confirm your security keys from your provider?
  • Thomas Lim
    If that is the case then the only option is to try first to connect to the Verizon modem using a computer with wireless. this will help you isolate the problem.Well at this point we know its the westell so the computer will just be used to be able to connect with some tweaks such as static IPs on the wireless. Granted you should not need to do this as it should work with the automatic or DHCP IP. Now what you can do is have verizon reset the westell or update the firmware and make sure the security on the westell is just set to WPA and NOT WPA2 as your palm may not support WPA2. Secondly have them change the channel on the Westell to 1 or 11. And make sure you try to connect atleast 10 feet away as if you are too close the signals will bounce.
  • Thomas Lim
    Thomas Lim Sep 19, 2008
    have you already checked if a computer with wifi is able to connect to the router? May I ask if you are seeing my messages?
    Sergeant:
  • 399 Answers
Computer
1. Go in to system>preferences>Palm OS Devices, that will open up gnome-pilot.
2. Click the devices tab
3. Click the button that says New
4. only thing you need to change is where it says type, change it to network
5. click close on that window but keep gnome-pilot open, has to be open for it to work
6. run ifconfig and note your local IP address
(mine is right after Inet addr:)
Palm TX
1. make sure your wi-fi is on
2. on the main menu go to "HotSync"
3. change the sync to network
4. under the HotSync logo there is a drop down menu, on there pick "Select PC"
5. go next
6. when it finds nothing click the "other..." button
7. put in the IP address of you computer
8. click done
9. click the HotSync logo to hot sync and you should sync up with Evolution. I am still finding out how to change the program it syncs to
Hope it helps
  • masterexpert Sep 18, 2008
    reset the PDA and then try
    hope this helps.
    thanks
  • 6,487 Answers
Can you please inform us the brand and model of your unit and also explain the prblem further so we can help you better with your concern.....
  • 2 more comments
  • Mark Gil
    Mark Gil Sep 16, 2008
    You need to make sure that the settings for your connection on the network is correct, if you're conencting wirelessly to a secured network make sure you supply the proper security key...
  • Mark Gil
    If you're connecting to your office network or to your own network you can get the wireelss security key from the wireless router or access pint, you can get that from your network admin...
  • Mark Gil
    Trun off the unit for about 10 minutes and make sure the wireless is ON with your PDA ..
  • Mark Gil
    Mark Gil Sep 17, 2008
    So the problem here is with your PDA try to reset the it and after that check if you can now select any available wireelss network...
    Guru:
  • 1,894 Answers
What is the problem you are facing
pelas explain it clearly
  • dewan nafees ahmed Sep 16, 2008
    what is the PDA you are having and what is the error you are getting from a year.
    what all steps have you tried to solve it til now.
    explain us the problem in detail sir.
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
Can't get local channels even though it is hooked up to an antenna
You may need to elevate the height of the antenna or verify the wire connections. If you have done that, try another convertor.
May 06, 2012 | Westinghouse TX-42F430S Television
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
I am not getting connected with wifi
according to the last firmware update they still do not support SDHC. I have a Palm TX also so I've been keeping a lookout. Sorry!
Jan 04, 2010 | Palm TX Handheld
Palm TX won't power up without charger
Replace the Battery. This has either a faulty Or Discharging Battery.
Even brand new items can have a faulty battery, or charging system
i,d suggest returning for replacement or refund, if it,s new/warranted.
Mike @ compurepair.
Jun 11, 2009 | Palm TX Handheld
Busy signal when trying to send fax
of course..is that phone line, by chance a high speed internet connection?
May 28, 2008 | HP PSC 950 All-In-One InkJet Printer
Palm tx
Does your linsys router have MAC filtering turned on in the WI FI settings?
Apr 06, 2008 | Palm TX Handheld
Device i/o error
My MuVO TX was having problems until I installed the latest firmware. The last firmware release was in March 2007. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo TX FM Firmware 1.24.02.
If you can't get your computer to even recognize the player anymore, you could try reinstalling the Creative Mass Storage Driver 1.07.00.250.
First of all, though, you should try changing the batteries, just to make sure that's not the problem. Sometimes the solution is a simple one! :)
Aug 23, 2007 | Creative Labs Nomad MuVo TX MP3 Player
VOX Transmit is "pulsing". Also, no wx channel reception
check if the mic is not dirty, there is nothing that you can do to fix this problem.
May 04, 2007 | Motorola Talkabout T6310 (14 Channels)...
Computers & Internet Logo
90 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
