Question about Canon imagePROGRAF IPF720 Printer
Page setup for printing
How do I change the orientation of the printed drawing? Have tried to change in the window preferences (Autocad program) but did not work.
Thank you
    Sergeant:
  • 320 Answers
In the file document you will find the tab called FILE. Click on it, and go to page setup. There you can change the edit the border or select the type of printing to A5, A3 etc.. And you can even also select landscape or portable. Thank you.....
Posted on Sep 17, 2008
Print preview does not show full page
Go into the Page Setup for the email program that you are trying to print from and this should allow you to change the print settings.
For example, in Mozilla Thunderbird, if I go into File then Page Setup, on the Format & Options tab I get an option to Shrink to fit page width, plus can change the page orientation (Portrait or Landscape).
On the Margins & Header / Footer tab I get further options I can use to control how big the page margins are and what header and footer information gets printed, i.e. page title, page numbers etc.
Once you've changed the Page Setup values, see what has changed for you on the Print Preview
Dec 23, 2011 | Dell Inspiron 15R Notebook
I have just purchased and installed a J3600 Officejet printer. How do I get it to orient the print for a #10 envelope, which has to be fed in lengthwise?
You'll have to choose "#10 Envelope" as your paper size in whatever program you are printing from.
Then pick "Landscape" in the print options menu when you go to print on the envelope.
Apr 15, 2008 | Office Equipment & Supplies
Canon ir3045n - when printing the paper orientation has switched to landscape. How do we change it back to portrait?
Hello Donna,
To change the orientation of the printer from landscape to portrait follow these simple steps;
- open any document and go to print from the file menu
- when the printers settings window opens click 'properties'
- In the next up coming windows you can see menus like 'main, page setup, effects' profiles
maintenance etc.
- click 'page setup'
- There you can see 'page size' and 'orientation'
- change the 'orientation' from landscape to portrait
- click ok and print
Done : )
please rate if this solution was helpful for you, thanks you!
Jun 23, 2011 | Office Equipment & Supplies
CHEQUE PRINTING CONFIGURATION IN CANON LBP3300
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size or page setup when printing from an application, taking Adobe Reader 6.0 as an example.
Note: The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note: The printer name displayed in this dialog box can be changed in the [Printers and Faxes] folder (the [Printers] folder for Windows 98/Me/2000).
Jan 27, 2011 | Canon LASER SHOT LBP 3300 Printer
ONLY A NARROW IMAGE OF A 'SKETCH-UP' WILL PRINT ACROSS THE MIDDLE OF THE PAPER, WHEN I WOULD LIKE A FULL PAGE (BOARDERLESS) IN LANDSCAPE ORIENTATION. WHAT SETTING AM I MISSING?
Before printing, configure the page setup on the application where you're printing from. Go to File -> Page Setup -> select Landscape orientation -> hit OK to save the setting.
To print your sketch, go to File -> Print -> Preferences/Properties -> from the Page Setup tab, select Landscape orientation -> from the Print Layout tab, select Borderless -> click OK to save the settings -> click OK to start printing.
I hope this information has been helpful.
If you need additional assistance, please contact Lexmark technical support.
Nov 24, 2010 | Lexmark X2580 Wireless All-in-One InkJet...
Prints from Manual Tray instead of Tray 4
Open a document. Select File>Page Setup and change the Source to Tray 4.
Or...
Try to print something. When the Print window comes up, select Preferences. On the Print/Quality tab look for the drop down menu labeled "Source is:" and change it to the tray you want. Click on the Save button.
Here is more info from HP:
HP M9050 Tray Configure
Apr 16, 2009 | HP LaserJet M9050 MFP Printer
I have a canon pixma ip4200. When printing it draws the paper in but then stops. The heads print as if the paper were there but the printer doesn't draw the paper through. please help...!
Use Fit-to-Page Printing (Windows) The Fit-to-Page function automatically resizes the image to fit the size of the page being used. Letter size image data, for example, will automatically be printed on 4" x 6" size paper. Paper sizes larger than the printer can handle will be available on the Page Setup of the printer driver but will not print unless the Fit-to-Page function is enabled. Note: The Fit-to-Page Printing function is not available when Borderless Printing is selected.
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
  3. Specify the 'Fit-to-Page Printing' settings.
(1) Select Fit-to-Page Printing.
(2) Select the size of original document created in application program. Paper sizes larger than the printer can handle will be available.
(3) Select the actual size of print media.
Click 'OK'.
I hope it helps!!!
Dec 02, 2008 | Office Equipment & Supplies
Print orientation
somewhere i believe you have auto rotate enabled in the driver, and it is cancelling your application's landscape setting. Good Luck!
Jul 15, 2008 | HP Designjet 110plus nr InkJet Printer
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
Canon imagePROGRAF IPF720 Printer Logo
69 people viewed this question
old marine
old marine
