Question about Navman GPS
Will not locate gps - Navman GPS
    Scholar:
  • 147 Answers
1. Do you have a clear view of the sky? Try a mall parking lot, or a sports field.
2. If it's new from the box, or has a factory reset done, or was powered up last in a different country, make sure the antenna is turned on, and that it's not in demonstration or simulation mode. Wait 12 minutes at least - so it can download the latest almanac from the first satellite it finds.
3. If you have a screen for signal strength, watch that, and reposition until you see at least 4 satellites with a signal level greater than 35 or 40 at the same time. Expect a fix roughly a minute later.
Posted on Sep 16, 2008
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
About 6 times, my GPS has frozen at one particular location along the way. Whenever I submit a location, the GPS provides the directions and mileage for that location without acknowledging the present...
Sorry to hear about the problem.
We mainly support Garmin GPS products.
Other than performing a reset, you may want to contact Magellan Support for assistance.
Dec 28, 2011 | Magellan Roadmate 5045 GPS 5inch Screen...
Will not find city or locations
Hello.
Solution to the problem.
With the right piece of hardware and software, it ispossible to triangulate your location anywhere on earth using satellitenavigation. These gamin devices cansuccessfully guide you from one place to another, or they can simply use theconnection with the satellite to tell you your exact current location. Thelatter function requires you to know how to locate the GPS device using theoptions onscreen.
1 Purchase a GlobalPositioning System (satellite navigation) product. There are manymanufacturers, including TomTom, NavMan and Garmin.2 Turn on the GPS and leave itfor a minute or so as it establishes a connection between the device and thesatellite.
3 Navigate to the"Current Location" option in the "Tools" or"Settings" menu (the exact pathway to this option depends on whichGPS device you have). The satellite signal will now successfully locate yourGPS device.4 Type a ZIP code or placename once you have located your GPS device. The gamin can now successfully guide you to your finaldestinationThanks.
Sep 18, 2011 | Garmin nuvi 255W GPS Receiver
Slow
Your GPS unit finds satellites based on your current location. if you are not in a wide open area then your GPS would need sometime to locate the satellites. You might want to upgrade your GPS for faster locating.
Feb 28, 2011 | GPS
My rightway gps is showing no gps signal
Important notes
1. First the GPS device has a display interface
2.Second the GPS device has storage data location
3.Third the GPS device is capable of broadcast connectivity
Description capabilities of the device
A mounted GPS makes possible an interface display area on which address locations are requested. The search request is performed by inputing an address wider area from which narrows a search.
An address location acquired on the GPS provides a roadmap from the initial location towards the destination address. Amongs several options provided includes the means to arrive at a selected address, where a loss of direction is adjustable to locate an areas.
Dec 21, 2010 | RightWay Spotter Dale Jr Edition Car GPS...
How do I change the start location?
The "current location" is based on the stellite tracking of your GPS. Turn it on OUTSIDE for 10-15 minutes and allow it to get a lock on the GPS satellites and it will get your actual location. There is no way for you to "force" a current location on the GPS.
Manual is available her:
http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf
Apr 01, 2010 | Garmin Nuvi 350 Car GPS Receiver
When i turn my navman icn310,its just says waitin for gps,wot does this mean
It means it's searching for GPS birds. The initial process may take up to 15 minutes for the unit to locate enough birds to locate itself. after it's located the birds and itself, subsequent power on sequences should be shorter in locating the birds.
Mar 03, 2010 | Navman iCN 330 GPS Receiver
Thinks the GPS is always located at home
Follow these steps to set your current location as home location.
1. Power on GPS
2. Touch "Tools" on screen.
3. Touch "My Data" on screen
4. Touch "Set Home Location"
5. Touch 2nd option "Use My Current Location"
Thats it !
--Sandy.
May 29, 2009 | Garmin nuvi 350 GPS Receiver
Screen stuck on location
Go to options
then user settings
then diagnostics
then set GPS position
then search by street and enter your location
this will bring you back to the set GPS position screen
Jun 25, 2008 | Magellan RoadMate 300 GPS Receiver
I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
90 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
