When press on button, nothing, no power. I've checked plug fuse and thats alright
    Sergeant:
    Champion:
  • 200 Answers
Hi
First check the plug point whether current is coming or not.
If its ok means then check the plug whether current is passing through that.
if its ok means then u want check the board..
See this link this will help u
http://www.repairfaq.org/sam/tvfaq.htm
Posted on Sep 16, 2008
    Genius:
  • 2,920 Answers
Power supply or power supply relay is bad
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
Power won't come on
hi, i take it you've checked the fuse in the plug, there's usually a glass fuse inside the washer power supply not sure where the circuit board is located in your machine but they usually sit at the bottom of the machine if it has blown make sure you put the same rated fuse back in. if blows again the there's a dead short somewhere hope it helps
regards
shaun
Nov 19, 2011 | Washing Machines
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and charge it via USB and nothing hapens
To do the hard reset, while on battery (NOT A/C) power, hold down the two outside front-panel buttons (Calendar and iTask), While holding them, press the reset button with the stylus. Keep these buttons all pressed until the image on the screen begins to fade (about 4 seconds), then you can release the reset and application buttons. To restart your iPAQ, you must then plug the unit into A/C power, or do a Soft Reset by again, pressing the reset button with the stylus.
Nov 21, 2009 | HP iPAQ H5455 Pocket PC
Bluetooth NS-BTHDST won't turn on
1- Plug the charger into a power outlet and connect the headset
2- Press the Volume Up and Volume Down buttons at the same time for resetting the device.
To Insignia: Please provide a line covering/linking this problem in Troubleshooting section of the manual, too. I found it in the Resetting section on page 22.
Mar 03, 2009 | Insignia Bluetooth Wireless Headphones...
No Power
Hai,
Yes, you have checked the fuse but there is no defect right.....!!!!!!!
Please check the power section some time if there is any problem means it will not turn on, i mean to say that inside the dvd player power section.
Jan 28, 2009 | Philips HTS-3555 System
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
