Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
PowerShot SD300 Flash Won't Charge
When I press the shutter button the flash charging symbol (a blinking lightening bolt) appears. It continues to blink, the flash never charges, and the shutter won't fire. If I turn off the flash, the camera works fine. Any suggestions?
I recently replaced the LDC panel on the camera, so maybe I did something during the repair??
  • 489 Answers
Hi
Yes its very possible that something was damaged during the repair. If you scratched a board you can break an electrical connection between two parts.
The thing to try first would be replacing the flash, look for a used one as it will be cheapest. If that doesnt work, then you have to replace the main PCB.
If you need parts, please let me know, its what we do.
Good luck from Darntoothysam com
Thomas
Posted on Sep 26, 2008
The flash of my sx30 doesn't work, when i open the flash it was detected that the flash is open but the the problem is when i'm going to shoot even i press my shutter it doesn't take any...
hion flash defuser unit up position, it doesn't allow to take picture. This means technically flash circuit is continuously sending charging signal causes blocking shutter release.( but not all of model, it is depend on model of camera.). Like this case, it is obvious that either a fuse brown or charge controlling pcb defective. I recommend you send to your local repair shop or canonUSA. They would charge around $45 to165 depend on what they really want to charge.
Jun 05, 2011 | Canon PowerShot SX30 IS Digital Camera
I have a Olympus FE-100. Everything works fine but it will not flash. Blinking red light. Blinking red lightening bolt. I have tried everything.
hi
blinking red light means camera is trying to charge flash circuitry. if you cancel flash mode, you can use taking picture. But if you want to repair, your local repair shop would charge around $35 to 75 depend on what they really want to charge.
Thanks and best regard!
May 23, 2011 | Cameras
How do i get the flash to work
Ascertain that the camera has an alternate buton to activate the flash. In situaiton that camera has an automatic flash would take effect whenever envrionmental conditions either lightening requirements were observable. refer to the cameras user guide to familirise with feature functiosn.
Mar 02, 2011 | Vivitar V5024 Digital Camera
Canon A720 IS camera will not take a picture when flash is turned on but will if flash is turned off. I see a flashing flash symbol in the LCD panel (as if it is waiting for the flash to charge) when...
Dear sir,
It seems  ur battery is weak , since it  use  AA battery put new alkaline batteries  & then try .. I beleive it will take pictures  with snap .
Regards
Raj@npconline.in
Feb 12, 2011 | Canon PowerShot A720 IS Digital Camera
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Canon SX10 IS Flash Problem
Hi, Even I have the Problem. The flash does not work at all. When I try to take pictures with Flash the camera hangs. Any solutions for this issue.
~Maddy
Jan 25, 2010 | Canon PowerShot SX10 IS Digital Camera
Can't get flash to work
• If you are taking pictures in low light (dim light) and the flash is required, the flash will operate
automatically. A lightning bolt appears on the LCD screen and blinks until the flash is ready.
• While holding the camera steady, press the shutter button to take a picture.
Hint: The flash works best when your picture subject is about 4 ft. - 7.5 ft. (1.22 m - 2.23 m)
from the camera.
• When the batteries are getting weak, the flash will not fully charge and the no flash lightning
bolt appears on the LCD screen. It's time for an adult to change the "AA" (LR6) batteries,
Hope this works!!!
Soyleonel
18
Nov 26, 2009 | Fisher Price J8209 Digital Camera
I have the same problem
The weaker the battery, the longer it takes the flash to charge. After taking a flash picture, you're supposed to wait until the flash has recharged before pushing the shutter button again.
Sep 13, 2009 | Canon PowerShot SD1000 Digital Camera
Canon flash does not work
The flash has to charge in between shots, so if you are not waiting long enough it won't charge and wont take the shot.
If you are waiting, Im not really sure...
Jul 13, 2009 | Canon PowerShot A610 Digital Camera
G9 flash
In your display, is the small lightning symbol appear on the screen? Try cycling through the various flash options by pressing the "flash" lightning symbol to the right of the monitor. If the flash is set to flash when there's not enough light at the G9's descretion (with an "A" next to the symbol) then the flash may or may not go off. I oftentimes set the flash to go off all the time if the camera is not doing it automatically (with the A next to the symbol). Being in Auto mode versus the other preset exposure modes affect the flash options available too.
May 20, 2008 | Canon PowerShot G9 Digital Camera
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
160 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
