I have a Canon Coalridge B F gas fire Serial Number 02787. I note that there was a product recall in 1998 from the London fire Brigade owing to the need for a modification due to these fires not igniting properly. In the case of my fire the pilot will ignite on the 4/5th try but aftre waiting the requisite 10 seconds for the pilot to stabilize and then releasing the knob the pilot is then extinguished. The thermocouple has been replaced but I still have this problem. Any ideas ?
5 Suggested Answers
  • 1015 Answers
SOURCE: I have been told that
I think before I went to the expence of buying a new fire place I would remove old thermocouple and take it to a heating equipment supply house and see if they can find a replacement. Most equipment manufactures don't make their own controls, such as thermocouples,gas valves ,sensors and other equipment. Many chain stores such as true value have good knowedgable people and if they don't have what you need they may know someone that does. I hope this helps you. thanks
Posted on Nov 09, 2010
  • 334 Answers
SOURCE: after igniting pilot and allowing gas to continue
sounds like you need a new thermocouple. Its the sensor that sits in the pilot flame and has a copper tube going back to the gas valve. All you need to know to get one is its length. They are cheap and usually found in hardware stores, It sends a signal to the gas valve, telling it that there is a flame once it gets hot.
Posted on Jun 13, 2009
  • 415 Answers
SOURCE: try to ignite pilot on
First, I'm assuming you have a residential Gas-Fired Heater or Water Heater that you are having problems with. My answer is based on this assumption.
Most thermocouples require that you hold the button for at least 45 seconds. Try holding the button for 60 seconds prior to releasing it. If this does not work, you can test your new thermocouple if you have a multimeter...preferably one with an alligator clip for your leads. To test your thermocouple, disconnect the end that screws into your gas valve. Set your multimeter to read Milivolts. Put your red lead on the copper line of the thermocouple.....it's easier if you have an alligator clip. With your pilot lit, hold down the button for 45 seconds and continue to hold while you put the black lead of your tester on the very end of the thermocouple (the part that attaches to the gas valve). You should read a minimum of 12 milivolts. If you do not read 12 milivolts, your new thermocouple is bad. If you are reading 12 milivolts, screw it back into the gas valve, relight, hold the button for minimum 45 seconds. Release the button. If the pilot goes out immediately, the problem (>99% probability) is with your gas valve.
Posted on Mar 06, 2010
  • 4736 Answers
SOURCE: Pilot light ignites, but fire
Not sure what type of gas appliance you're having a problem with. If it's a vent-free gas heater, fireplace or gas log set, this problem is usually associated with a clogged Oxygen Depletion Sensor (ODS), which is a safety feature. In addition, based on the age of your unit and whether or not it has had regular annual maintenance, it could be the Thermocouple or Thermopile has failed. The latter can occur with both Vent-free and Vented Gas appliances.
If you will get back to me through the comment section of this page, with more specific details of what you have, I can help you further.
Posted on Mar 18, 2011
  • 4736 Answers
SOURCE: Valor flamenco unigas 2 fire
Valor uses either a Thermocouple or Thermopile, depending on the unit. In some cases, it has both. And, yes, your assumption is probably correct. Some thermocouples are a part of the Pilot Assembly, which means you have to replace entire pilot assembly. If you check you Owners Manual in the Parts Breakdown section, it will indicate if it is or not and whether you need a Thermocouple or Thermopile or both.
If you're not familiar with repairing gas fireplaces, replacing the parts listed above, can be a little challenging. Especially if you don't have the proper tools. But, before you jump on this project, try cleaning the Pilot Orifice first. You can easily do this, using canned compressed air with a straw nozzle (like you clean your computer with) by blowing out the pilot tip. And while you're at it, clean all around the pilot assembly with the canned air. If cleaning the pilot solved your problem, you're back in business. If it didn't you'll have to go the other route.
Hope this helps you solve the problem. Please be kind enough to rate my reply to you. Thanks!
Posted on Mar 24, 2011
I HAVE A BEKO FRIDGE FREEZER MOD CGA 963 NS SER NO 0510054901 COULD YOU PLEASE TELL ME IF THIS PRODUCT IS SAFE
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I can ascertain, the fridges affected were manufactured between January 2000 and October 2006 (So, after shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008)
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
Jul 06, 2011 | Beko Refrigerators
My beko fridge serial number is 0510273603 is this one of the unsafe ones
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
I have to say. Regardless of dates and matching serial numbers, if I had an affected model, I would be checking with BEKO anyway!!
Jul 06, 2011 | Beko TLDA662
I have beco fridge serial number 0210011801 model number cga 96cw class sn type 1 please advise on the recall off the fault on them
From the list that I have, I would say no. But please take a look at the following to reassure yourself:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
Jul 06, 2011 | Refrigerators
Fridge freezer serial number 0210099207 product no FN244S is it at risk of catching fire
I'm pasting this response on all queries regarding the recently announced issue with BEKO fridge freezers and the risk of fire from their defrost mechanisms, but I have placed it here in hints and tips too, in the hope it will be of use to any concerned BEKO Fridge owners:
According toseveral sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what Ican ascertain, the fridges affected were manufactured between January 2000 andOctober 2006 (So, after shipping and sitting around in shops, you can probablyextend that margin to machines SOLD between 2000 and 2008)
If you go tothe BEKO website, there is a link to check your serial number:
I have tosay. Regardless of dates and matching serialnumbers, if I had an affected model,I would be checking with BEKO anyway!
Jul 05, 2011 | Beko Refrigerators
Have model cda647 F / 648 F who we have been alerted may have design fault. Please advise if we need product engineer to site visit
CDA647FS and CDA647FW do appear in the list. Please see the following article I have created
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
Jul 05, 2011 | Refrigerators
Fridge freezer fire risk
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
(And by the way I DO have a BEKO fridge freezer and I will be checking it out when I get home!!)
Advertised on the TV Today that there is a fault on about 20 Beco Fridge Freezer Modles, made between 2002 - 2007, We have a Fridge Freezer Model CDA 563 F, is this one of the Modles concerned
According to the London METRO magazine and several other sources I have checked( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
But I have to say, matching serial number or not, if I had an affected model, I would be checking with BEKO anyway!!
Need list of serial numbers of fridges affected by likelihood of catching fire - reported on BBC Radio 4 this morning
According to the london METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I can acertain, the fridges affected were manufactured between January 2000 and October 2006
But I have to say, matching seial number or not, if I had an affected model, I would be checking with BEKO anyway!!
Our fridge/freezer FN240-FG940 was purchased in 20002001. Is it subject to the currently identified overheating problems please?
This article refers to BEKO Fridge Freezers:
According to the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
Please can you tell me which serial numbers on fridge freezers have a problem
If you are referring to the potential FIRE RISK announced on the BBC today, this issue refers to BEKO Fridge Freezers:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
Heating & Cooling Logo
463 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
