Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Could you tell me which is the hot water connection, left or right on back of machine?
  • Kenmore Master
  • 5,568 Answers
Use a flashlight and examine the sheet metal around the inlet fittings; they almost always have a 'C' and an 'H' stamped into the metal covering the back of the machine.
Posted on Sep 22, 2008
Kenmore elite washer model 796.4174 is leaking right below the supply line in the back out of what looks like an overflow valve. Is there such a thing?
The washer usually has 2 water supply line, one for cold and one for hot. You must have connected only one and water is spewing out from the other.
Jan 11, 2014 | Kenmore Washing Machines
Auto temperature control is incorrect, the setting cold cold is Hot Hot
Maybe check that each hose is connected to the respective water bib, Hot to Hot on back of washer cold to cold?? It is easy to confuse these during machine hookup. (Worth a shot anyway).
Dec 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 300 washing machine warm water cycle is hot water
You have to check the thermostat connected to heater circuit.
Apr 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite T3 washer that occasionally fills with a gallon or so of water when it is done with a load and turned off.
It sounds like your water inlet valve is not sealing properly. The valve is part of the (hot and cold) water hose connections and is plastic. It is screwed onto the back panel of the machine. . Easy to replace prices range from $25 to $55 for the part. Until you can get the part you can manually shut off the water to the machine when not in use.
Aug 03, 2009 | Kenmore Washing Machines
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Washer Impelling into Hot Water Line
this sounds impossible,hold old is the washer? how long are the hoses to the washer?is it the temp pressure valve on the heater that bursts? can you hear the water draining out the drain pipe, this machine don't go into spin till the water has been drained.
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
