Question about Acer Aspire 3680 Laptop
Compatibility issue between texax instruments pc1xx12 flash media reader and window vista;problem caused by intel graphics driver
Vga driver not install on win7 i dont have an idea what vga is built in and who i find its driver
Your Sony VAIO VGNC Series were desiged for Windows Vista. Windows XP is compatible with this computer as well. The Video adapter installed in this computer Intel® Graphics Media Accelerator 950. According to Intel, this video adapter is compatible for Microsoft Windows* XP, Windows* XP 64bit, Media Center Edition 2004/2005, Windows 2000; Linux-compatible (Xfree86 source available). The only way this computer will work perfectly is to downgrade your Windows 7 to any of the mentioned Windows versions.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
May 08, 2011 | Sony VAIO VGNC Series VGNC21GHW VGNC22CH...
Not compatible issue
You might be able to find a Windows 7 graphics driver from this site for your graphics card :-
Driver Cure - Windows® 7 32-bit and 64-bit Operating System, Windows Vista® 32-bit and 64-bit, Windows® XP 32-bit
www.paretologic.com/lp/drivercure/lp8/index.html?gclid=CMCPwP7jjp8CFRelagodPW_eGg
Jan 25, 2010 | Acer Aspire 4315 Notebook
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
Resolution issues since vista upgrade
Just force and install the driver, It should be working good. I too had similar problem. I just forced and installed the driver even though it said that its not compatible.
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
D845GLVA - vista Home Basic - Display drivers
sorry no vista support for this board u have to get an ext graphics card for vista support nvidia ,ati , all are good
pls see this ur self ur on board vga doesnt support vista
http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
pls rate me fixya for this if u like
Mar 12, 2009 | Intel Desktop Board D845GLVA...
Drivers Problem
I know what the problem is but the solution isnt aviable yet.
Vista has issues communicating with the driver even if it says its in propperly, intel has yet to release an update for this or microsoft a solution ,, here is the driver link
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065&lang=eng
NOw here is what you can try
In vista go to the control panel and select classic view
(START/ CONTROL PANEL / CLASSIC VIEW)
there are 2 ways
1.) Select windows update and let it update windows it self, hopefully microsoft has realeased compatibility protocols to solve the issue
2.) Select Problems and reports, the problem will be listed here, have windows keep checking for a solution, it will search the microsoft data base as well as intel and keep checking for drivers..
Other than this you only other choice is to downgrade back to xp until a solution is avilable.
Jul 13, 2008 | Intel D845GVSR Motherboard
Lost resolution windows vista upgrade on GX260
Hi all,
I tried numerous solutions for this issue and none of them worked except this one. I tested it with Vista Ultimate and don’t know if other Vista versions have the same drivers but here’s what worked for me:
1. Right click ‘Computer’ then left click ‘Properties’ to open up System window.
2. Click ‘Device Manager’
3. Click ‘+’ on ‘Display Adapters’ and you should see the drivers for your video. Right click and select ‘Update Driver Software...’
4. Select ‘Browse my computer for driver software’ and click ‘next’.
5. Click ‘Let me pick from a list of device drivers on my computer’
6. Untick ‘Show compatible hardware’
7. Select ‘Intel Corporation’ then select ‘Intel 82865G’. Click next.
This will install the drivers. No they are not the same drivers for the hardware but they work a treat!
May 05, 2008 | Dell OptiPlex GX260 PC Desktop
Compatible games for my loptop
hai
you can play any games which requiers 128mb of graphics card
not a games like advanced 3d graphics game
see the game requriement before installing
if you install more games the system might be slow
Mar 20, 2008 | Acer Aspire 5610 Notebook
Acer Aspire 3680 Laptop Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
