Tv lcd screen damaged/cracked screen distorted
  • 2 more comments
  • Anonymous Mar 17, 2009
    32" Element Screen made by ProScan
  • Michael2121 Apr 03, 2009
    Same here with Sanyo VPC-T700
  • lopezrollin1 Apr 30, 2009
    my nephew hit the tv with a bat and the screen is cracked
  • capable305 May 14, 2009
    i have a 42in samsung and myh girl hit it in the corner and cracked the screen what can i do
  • 4,234 Answers
If the LCD panel itself is physically broken, it must be replaced. It can not be repaired. If you could post the make and model, I can try to get you the replacement part number and cost. Realize that this cost may exceed the cost to replace the entire set.
Dan
Posted on Sep 16, 2008
Lg 42 pc1d-ec
Posted on Apr 20, 2009
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
What is happening to my TV? It's as though a red blotchy haze appears in the left side of the picture. I'm so sad!
What kind of TV is it? In the old days of CRT TVs if you put a strong magnet next to the screen, it slightly magnetizes the screen and corrupts the picture. Many TVs had built in "Degause" ability so look in the manual or download the manual to check.
If it is a LCD it could be damage to the screen. Many LCDs will distort the picture when pressure is applied to the LCD screen. This is usually not fixable except to replace the screen. If the LCD screen is being twisted in some way, like a warped cabinet or something pushing on it, that MIGHT be fixed. Remove the pressure if possible and it might help.
Oct 26, 2015 | Televison & Video
I have a lcd samsung tv but it now has i spidr web crack in middle of screen can it be fixed and how much will it cost
A spider web crack in middle of screen means lcd panel got broken and need to be replace that would cost approx new tv price, replacement lcd panel would be available in nearest Samsung service center only.
In my opinion, new tv would be good option.
Thanks.
Jun 03, 2011 | Televison & Video
I have a 52" Toshiba
in general cracked lcd panels cost more than the tv is worth.. depending on model panel replacment run 1500 to 2000.. and physical damage is not a warrenty item. do you have a toshiba or a rca the decription says you have rca r52wm24 which is not a lcd. that is a tube tv. and if it is cracked that definatly can be fix or replaced cost effective.
Oct 27, 2010 | RCA R52WM24 52" HDTV Projection Television
The screen is cracked and distorted can it be fixed the inside is not on the outside Mitsubishi 42 INCH FLAT SCREEN TV serial number LT46133
IF it is a LCD OR PLASMA AND SHOWS A CRACK INSIDE THAT IS can be seen---you are finished.
It means Panel is damaged internal--cost of part alone will be as much or more than set cost, not counting labor(major).
I do not like giving bad news. If you have questions or need advice comment on this solution
If this told you something you did not know rate this solution very helpful as I do this here for free.
SD TECH
Aug 24, 2010 | Mitsubishi Televison & Video
I need a new screen mine is cracked
Sorry not worth fixing,because DLP,LCD or Plasma tvs screen panels are broken or damage.Will cost the same as a new tv to do the replacement of the screen panels.No where u will able to buy any tvs screen panels anywhere,except the tvs corporations themselves.The screen are 90% of the tv,damage or broken screen panels tv not worth as a whole tv anymore,now only worth as salvage electronics boaards parts.
Jun 18, 2010 | RCA HD52W56 52" Rear Projection HDTV
Cracked lcd tv screen
it's over with when you crack the lcd screen, the lcd assembly costs more than the whole tv. cheaper to replace this unit.
Sep 08, 2009 | Televison & Video
Distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Broken Screen
You need new optic block. Sony will pay for repair if you contact an authorized SONY repair facility
Dec 19, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
434 people viewed this question
Top Televison & Video Experts
Electro Med Services...
