Printer HL 5250 DN. .
Paper goes everywhere on exit
  • 691 Answers
Try putting a cardboard box under the exit point to catch the paper. This will stop it from going everywhere.
Posted on Sep 16, 2008
HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
May 18, 2010 | Brother HL 5250DN Laser Printer
My hl 5250 dn printer is printing a wide horizontal line on the leftside about 1/3 way in. How do I fix?
The problem mostl likely is that the handle for cleaning the corona wire isn't at it's start location. You can fix this by simply open the machine, unmount the toner/drum package and move the corona cleaner (the blue/green/grey marker) on the drum unit to the start position so the two arrows face eachother. This should solve the problem.
Jun 08, 2009 | Brother HL 5250DN Laser Printer
Wrinkled Left front corner
Sounds like you have a burr on the paper guide fins. Look for a small nick in the plastic guides fins which can simply be filed smooth with a small file.
May 26, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
rolf@edeborg.se
Jan 19, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 26, 2008 | Brother HL-2070N Laser Printer
SOFTWARE DOWNLOAD NEEDED
Need software for Laser HL-5250 DN
Apr 27, 2008 | Brother HL 5250DN Laser Printer
HL 5250 dn
first you most clean the printer carefully then you most change the drum unit
Feb 28, 2008 | Brother HL 5250DN Laser Printer
Brother 5250DN printer noise
Check my solution here:
http://www.fixya.com/support/t641678-paper_tray_noise
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Nov 02, 2007 | Brother HL 5250DN Laser Printer
37 people viewed this question
jasbo
jasbo
