Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Wsm2420d1ww GE washer Stacktop wont spin th clothes dry
My washer will not spin the clothes dry ,I put a new timer in it with no change in the spin. it has a slow spin on both spin cycles. It washes fine but when it first drains it will only begin to spin after you push in the timer and pull it out again.
SOURCE: GE frontload washer will not wash cycle or spin out
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
Posted on Nov 22, 2007
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may not align perfectly but don't worry, just get them to go back in the hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
Posted on Apr 15, 2008
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Posted on Jul 03, 2009
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Water not drane setisfewctori Cloth not dry
There are 2 possible reasons for this .The drain for the washer may be kinked at the back preventing the water being pumped out . The pump is virtually a water circulator and not a pressure pump so any obstruction will keep water in the washer.. Next --the spin cycle may be to slow for the water to be spun out of the clothes. Check the load is not above the recommended weight as this makes the spin cycle slow. IT is better to do 2 washes rather than to cram it all into 1 wash. Check the filter at the pump as they tend to block up with lint and other gunk from the clothes and the water may be unable to get to the pump Powdered detergents are 90% clay( fine as talc powder and used to carry the detergent) and this settles out in the lower parts of a machine so if you use powder I would recommend changing to liquid
Mar 11, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Not spin drying clothes enough
IF YOU ARE YOUSING A MANUAL MACHINE WITH gentel / normal dile settings ,the problem would be the dial is stuck on gentle load and not selecting normal load spin ,[ Two things ]
1 the wire to the normal contact can be changed to the wire on the gentle contact and put the removed wire off the gentle contact on to the normal spin contact of the dial this will give full spin only if this fails replace the spin dry switch assembly
2 if a timer is involved then the timer will need to be changed [ new one fitted ] BE SURE THE POWER PLUG IS WHERE YOU CAN SEE IT [ AND NOT PLUGED INTO ANYTHING ]
IF
Mar 05, 2011 | Maytag PAV2300 Top Load Washer
My GE washer wont spin
any small cloth which remain inside the spinner during past spinning of cloths may cause.....do clean dry cleanig without cloths or open the beneath shed and watch if there is any another problem with it. Please to help you!
Jan 20, 2011 | GE Washing Machines
My washer washes clothes but when it gets to the rinse cycle it stops. i have replaced the timer and still does the same thing. what else clould it be?
when it gets to the rinse or when it gets to the spin? it may be the switch for the lid, meaning the washer may think th lid is open and it wont rinse or spin. try this: try to get at the two wires on the back of the lid switch and tape them together, if it works than your good to go, or you can put a new one in but you really dont need it.
Nov 29, 2010 | Washing Machines
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
289 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
