Question about Philips Magnavox 51MP392H Rear Projection Television
No power to tv
I have a 60 in rear projection. worked fine last night but today no power at all. remote or on switch on tv. what could be the problem
  • 2,920 Answers
Power supply or power supply relay
Posted on Sep 16, 2008
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
The tv is on the wrong input. Try running through the different tv inputs with the remote. If you have a cable box make sure its on. Hope this helps.
May 28, 2011 | Toshiba 46HX83 46 in. Rear Projection...
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mr rca rear projection tv just came on last night on it's own. i can now only power it on by the front power button. tv has no response to any other buttons on front console and no response to remote.
hi,you need to replace the front control panel, 1 or more of the tact switches have failed, if your proficient at solder work you can replace the switches, if not replace the small board behind the front buttons, available from any local tv shop just bring them the complete model # of your tv, gl, video-tek
Jun 04, 2009 | RCA P52921 52" Rear Projection Television
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Television won't turn on.
The same problem i am also facing bin last weak what i will suggest you that neverturn off ur TV by remote switch off directly from the scree from next time it will be helpful for you from next time...
Thanks & Regards
May 24, 2009 | Televison & Video
No sound
check your remote to see if it's on mute...or mute is enabled...check your connections from the tv to the cable box...if your using surround sound...check those connections as well...if you have a dvd player..hook it up to the tv and see if you get audio...let me know if this helps...if not i will give you more things to check
Feb 07, 2008 | Philips 60P8341 60" Rear Projection...
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
74 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
