Question about Vacuums
Vacum has no suction - Vacuums
  • CHAPELUSA Sep 16, 2008
    MY VACUM HAS NO SUCTION DIRT DELVIL 2 MONTHS OLD I HAVE CLEANED OUT ALL HOSES ETC
    Sergeant:
    Champion:
  • 271 Answers
Do the vacaum power up as normall..hows the sound?
Posted on Sep 16, 2008
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
No suction
hey, how are you ?
here are a ew things that could be causing you sorrow
1.) Check your vacume to ensure that it isnt clogged anywhere
2.) before your compressor and after the filer, this part is where the suction takes place, check to see that it isnt clogged or that it isnt broken...
3.) check your packing (diapharam) in the vacume oto see if it ruptured(has a hole or broken)
4.) Check for lears on the vacume, basically run a pice of paper all over it and see if it is pulled to the vacume.
Once air is coming out the back, it means the compressor is working, but it alos means that the vacume is clogged, or a compartment that is u\supposed to be sealed is broken, or it has a leak somewhere..
My bet is that it is clogged somewhere, take it apart you will find it..
Jan 09, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
No sucking
if you have no suction - then the problem could be a dirty filter or a blocked suction hose. clean the filter and check the hose from top to bottom for blockage. if all is clean and clear and you still dont have suction then the problem could be a bad vacume suction motor.
c...
Feb 02, 2011 | Hoover U5175-900 Fold Away Bagless Upright...
POWERMATE HEAD DOESNT SEEM TO HAVE GOOD SUCTION AND IS LOUD
suction wise have you checked the internal pipes on your vacum as for the load noise if it is quite a load noise a humming noise it is ure motor so not worth fixing motors r pricey for a vacum
Feb 03, 2010 | Kenmore Vacuums
BEAM VACUM DOSE NOT WORK GOOD BECAUSE SOMETING SUCKED IN THEIR
Check to see if you have suction at the outlet, if so
the plug is in the hose or wand. If no suction at the wall, check at the vacuum. If you have suction at the vacuum then the line from the vacuum to the outlet
that you were connected is where the plug is.
Try a plumbers snake to try to get plug out.
Tom
Oct 22, 2009 | Beam Industries 2900 Serenity Plus Central...
The suction in my vacum is not good. I changed
Depending on the type of vaccuum you may have another filter. I have a hoover and there is the hepa filter and another filter under the dirt container. If thats not the case, try taking off the entire hose and shaking it around. There may be stuff crammed in there. If one thing gets stuck, then everything else sticks to that. I had the same problem and when I took off the hose and shook it, a bunch of nails fell out (remodeling) and it worked fine after that.
Aug 19, 2009 | Vacuums
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I just purchased a DC07 Dyson vacuum cleaner. It is not vacumming my floor - I have hardly any suction at all. Do I need to activate something in order to initiate the suction?
With vac upright suction is sent to the hose ie top of vac handle when handle is tilted down to the user vacuum position it should send the power suction to the floor also make sure collection bin it in securely that make be the problem
Sep 08, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
