Question about Whirlpool LER5636P Electric Dryer
Thermal fuse having the same issue with my dryer not starting. You mentioned a thermal fuse...how do you test that fuse??
  • Anonymous Sep 17, 2008
    Have a Whirlpool LEC8858EC2 dryer. Thermal fuse shows no continuity, so it worked. Since its part of the electric motor circuit, I'm assuming the motor is drawing too much current. Is this correct and should I be looking for something wrong with the motor, or something else, for the fuse to function? Motor resistance reading between fuse blue wire and white wire on temp select panel reads ~2.8 ohm. Vent is kept fairly clean.
    Genius:
  • 1,028 Answers
With a volt ohm meter ck for continuity ..or unplug connect the 2 wire ends together and reconnect power turn on and ck..but be sure to ck vent system first for blockage before replacing fuse..but could also be bad door switch or timer
Posted on Sep 16, 2008
My Samsung electric dryer runs but doesn't get hot
Clothes dryers usually have one of three issues when they fail to heat.
Taking a good electrical meter ( with ohms readings), check first the heating element.
If it checks good, then try all of the thermostats and the fuse. (There may be as many as 5 thermostats.)
You will need to unplug the wires off of each of these items that you are testing before you test them.
Whilst you are looking, be sure to test the two hot leads from the circuit breaker box, because one of the two hot lugs is for the machine operation, one is for the heating element.
God bless your efforts.
Jan 19, 2016 | Samsung Dryers
Dryer motor not starting
Have you tried checking power at the motor? Try going back over everything you mentioned as though it is the first time.
Jan 18, 2013 | Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Did you resolve the issue with the Kenmore Elite H3 Dreyer of just beeping and not turning on? I can be reached at the email below - Thanks - It lights up and just a beep and a clickng noise when you hit...
    There's a thermal fuse located on the blower housing that blows when the vents and ducts are clogged or when the thermistor, also on the blower housing, fails. This thermal fuse is wired in series with the motor and if blown, power to the motor is terminated causing it no to run. The motor activates the heating circuit through the motor centrifugal switch only when the motor runs. No dryer function works then when the motor cannot run.
    Access then bypass the thermal fuse and if the dryer runs, the thermal fuse is indeed blown. Make sure the vents and ducts are clear then replace the thermal fuse including the thermistor to address the problem. Do not use the dryer with the thermal fuse blown due to fire hazards. Click on the link below for the detailed troubleshooting procedures.
    Troubleshooting Whirlpool Duet and Kenmore Elite Dryers Not Starting
    Note: The part numbers mentioned in the link above may not be the right one for you dryer. Indicate the exact model number of the dryer should you need the right part numbers.
    Feb 23, 2011 | Dryers
    HI, my dryer stopped working, check belt it not broken and in place. So what can it be. Can it be the starter button?
    Hello there and thanks for choosing fixya
    Investigate these areas if your dryer is not starting:
    Proper Voltage from the House
    Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
    dryer_door-switch.jpg Door Switch
    If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
    dryer_start-switch.jpg Start Switch
    A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
    dryer_thermal-fuse.jpg Thermal Fuse
    A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
    dryer_thermostat.jpg Thermostat
    A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
    dryer_timer.jpg Timer Motor
    Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly.
    dryer_motor.jpg Motor
    A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
    Jan 23, 2011 | Dryers
    Dryer won't start
    When the dryer wont start it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it is the main board that has gone bad & you will have to replace it to solve this issue.
    Hope this will help....
    Dec 31, 2010 | General Electric DBSR463EGWW Dryer
    Whirlpool crosley dryer cbe227v, the dryer will not start, you can here it hum but it wont actually start.
    If the dryer won't start then it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it is the motor that has gone bad as the hum sound comes from the motor & you will have to replace it to solve this issue.
    Dec 31, 2010 | Dryers
    My dryer wont start or turn on at all
    Dryer turns on but will not heat up.It has not been used for two weeks. It worked perfectly then. Is there a fuse or a reset button? Electricity was off periodically,
    Check for a blown thermal fuse. It is located just inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter or ohmmeter. A lack of continuity indicates a blown thermal fuse. Another cause of not heating would be a faulty heating element, but with the electricity issues you mentioned, it is most likely the thermal fuse. Hope this helped and best wishes.
    Aug 11, 2009 | Dryers
    My Maytag dryer won't start when I hit the start button
    It sounds like that you have found the problem yourself. Remove the power cord and replace the terminal ends, or replace the entire cord.
    Dec 28, 2008 | Dryers
    Whirlpool LER5636P Electric Dryer Logo
    57 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Richard Roth
    Richard Roth
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
