Question about Kenwood KW85 Air Conditioner
Error : E3 FAULT
Good afternoon, koakako
I have acondicionador portatil DeLonghi cf208. This is a problem in display error E3 FAULT. yourself dont remot control
Thank for solutions
miguelmar33@gmail.com
  • 2 more comments
  • johnson6905 Oct 05, 2008
    e3 fault
  • Maarten Steenkamp
    Maarten Steenkamp Mar 31, 2009
    same = E3 - no cooling + use of remote stop aircon (any button)
  • Anonymous Apr 01, 2009
    I have the same problem. My display reads E3 how do i fix it
  • sadam Jul 19, 2013
    F8 FALT
I have problem ac indoor come on display e3 error problem kindly give me solution
Posted on May 05, 2012
WE HAVE PORTABLE AC SPT USA .This is a problem in display E3 FAULT
Posted on Sep 21, 2008
What is error code E3 in washing machine Beko 91242 LC
This error code is below. Good luck to you:
E3
Constant heat
Nov 25, 2014 | Beko Washing Machines
E3 Error Message
E3 indicates a sensor fail - most probably the humidity sesnsor. Or it could be a fault in the display itself. Are all the functions working properly?
May 28, 2013 | Humidifiers
Code reading E3 F-1
Thank you for using FixYa. F1 refers ro a fault with either the control board or touch pad. Both may need replacing to clear this error. E3 refers to a fault with the temperature sensor and should be replaced. This unless the repair done by yourself may work out expensive.
Sorry to be the bearer of bad news.
Mar 04, 2011 | Ovens
Our delonghi de400p dehumidifier shows an E3 error message. Customer Service says its a sensor but can't tell us what sensor. Any help would be appreciated.
I have a 40 pint and a 50 pint that are very similar. The 40 pint has the e3 error. Experimenting with the 50 pint, I found if I disconnected a particular sensor I got the e3 error. That sensor is a little can with two black wires (smaller than a AAA battery but shaped like that). It is attached to the cooling coils so must be a temperature sensor. This is not the little circuit board sensor mounted in the middle of the radiator in a plastic box/clip thing.
I am now about to see that part to see if I can replace it.
Jul 09, 2010 | DeLonghi DE400 Dehumidifier
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Error Code E-3
i don't know if this will help i have a delonghi portable ac and the e3 means not enough voltage to run properly. but it was doing the same thing as yours. i plugged it in where i knew there was good enough voltage and it works fine now
May 26, 2009 | DeLonghi DE500 Dehumidifier
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
CF 210 Delonghi
i just found out that e3 means voltage problems. i plugged my into a place i knew would have enough voltage and it started right up with ac
Sep 10, 2007 | DeLonghi CF210 Portable Air Conditioner
Kenwood KW85 Air Conditioner Logo
5,604 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
