I have a Toshiba CF26C30 with no HV, no audio. I am working with no schematic. At the regulator Q801 I have 41 volts on pin 1, 160 volts on pin 3, 38 volts on pin 5 and 0 volts on pin 2 and 4.. I have no voltage on Q421 and Q423.. I can see these test points that should have 9 volts and 5 volts and I have no voltage. I have 32 volts and that test point..There is no voltage going to the vertical IC..I know I am asking a lot but can someone guide me in the right direction.. Thanks for your time and effort...
lyzmorato
I Apologize For Saying Your Solution Did Not Work.
i.e.
The speaker you got...
(More)
lyzmorato
i.e.
The speaker you got is USB powered. Upon connecting it to your Mac, it should undergo the Auto Detection process. When you connected it, do you see any signs of power on the speaker? If yes, it is getting power. After connecting the USB cable, connect the headphone jack to the audio jack on your Mac.
Please see diagram below. If you have any clarifications, please comment back. Thank you, lyzmorato
To Which I Responded;
When I Connect As Shown In You Diagram (By The Way,Nice Diagram), How'd You Do That ?
The USB Port Is Connected To The USB Input Port Of My Mac.
The Speaker Connection When Connected To The Headphone Jack On My Mac, It Registers As Under Name "Headphones" Under Type It Says "Built-in Output".
When I Switch Jacks On My Mac To The Other Open Jack [Speaker Output], It Says Under Name "Internal Speakers", & Under Type It Says "Built-in Output".
I Did NOT Accept Your Fix, & Again I Apologize For That.
I Can Consider This Matter Closed
Hope This Gets Posted On "FixYa"
When I try to install my cam Model no: IC 50 C from my CD it says there is an internal failure :...
(More)
When I try to install my cam Model no: IC 50 C from my CD it says there is an internal failure : 0x80040707. I tryed installing it online as well, I still get the message, any suggestions?
