Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Water behind screen
My 3yr old poured water in the corners of the screen. Water is trapped behind the two screens. How do I get the screen off to dry? Having trouble getting the speaker board off- tech said something about screws being behind this board. Thanks- Michele
  • 10,594 Answers
There is solution posted in This Link, might help you out.
Posted on Sep 16, 2008
I had water drip from the ceiling onto the front face/screen. It appears water dripped down between the bottom bezel and screen. Now there is a 1"x2" dark spot at the bottom of the screen. It...
Hi Kevin this type of problem needs to be serviced. What you see is liquid trap in the LCD screen that might damage other parts of the LCD if you wont fix it. If its under warranty call the Mitsubishi support.
Feb 01, 2011 | Mitsubishi WD-65733 65" HDTV
Tip
Dryer - Tips for Cleaning Dryer Lint Trap!
Most people know where their lint trap is and most know or think they know how to clean them. BUT do you really know? For the people that use the fabric softner dryer sheets, they might find out that they still have not cleaned it properly. So if your dryer seems to take a longer and longer time to dry your clothes you might want to check this little tip out.<br /><br />Remove your lint trap and clean it normally. Then take it to your sink and run water onto it. IF the water doesn't pass through it immediately you have a blockage! You can't see it, but your dryer sheet is leaving residue on the screen and slowly building up.<br /><br />If there was any blockage, then you can use an old toothbrush to clean it. Just the toothbrush and water. To check to see how well you did run water and see if it passes through the screen immediately.<br /><br />This will increase your dryer efficiency and you save a little energy in the process.
on Jun 22, 2011 | Dryers
Tip
IS YOUR DRYER NOT DRYING?
If you are discovering that your gas or electric dryer is not drying as good as it used to, it could be the dryer sheets! Really, some dryer sheets have a water soluble softener that over time will plug up the small holes in your lint screen and will not allow air to pass through. Periodically wash your lint screen with hot water. If you pour water on the lint screen and the water beads up, it's time to give it a good wash.
on Feb 09, 2010 | Dryers
Have a terrible smell coming out of my tub drain
I hope you put trap back on,or you need to fill trap with water--that is the water seal for sewer gas
Jan 31, 2011 | Kohler 1107-R-0 ProFlex Bath Tub with...
Working on a 3yr old rheem water tank 22v50f1, pilot doesn't stay on, replace theromcouple and problem persist, cleaned air intake screen... what do ???
Sorry to read about your problem, I hope this helps you out.
That means you gas control valve is defective....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I need to run the dryer through 2 drying cycles to completely dry also using the sensi dry
Rince the lint trap off with hot water , when you do and water beads up on the surface, wax has built up on the screen from the softener and has pluged the screen, rince till water flows through freely, if this dos'nt work check the outlet and tube for lint buidup
Oct 17, 2009 | Kenmore Dryers
Water trapped in lcd screen
try placing the cam on your dashboard or other hot surface for a while. maybe use a hairdrier to dry up the moisture.
Jun 01, 2009 | Sony Video Cameras
Dryer takes too long to dry a load
Have you checked the lint screen? pull the lint screen out and remove the lint then hold flat and pour water on it. Does the screen hold the water or does the water flow through? If it holds water, then you must actually clean the film that has coated the screening material. Use dish soap and scrub lightly then rinse clean. and check again.
Apr 02, 2009 | Kenmore 62872 Electric Dryer
LG viewty Water in touch screen
if your phone gets wet, putting it in a bowl of dry rice over night is supposed to dry it out. hope this helps. :)
Feb 10, 2009 | LG KU990 Viewty
Water Damaged lcd tv?
Hi there.My 3yr old son water gun our 50" lcd tv sony bravia.I nearly have a heart attack.LOL.There were black mark at the bottom of the screen and when I touch it it's moving around.I realize that it was the water.So I didn't do anything.When we don't watch tv I turn it off from the wall.I kept doing this and after two weeks I notice that the black mark has gone.I don't why>So may be you could just leave as it is...good chance it may to away itself.I hope this helps.thanks.
Mar 23, 2008 | Televison & Video
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
