Question about Hoover F5886-900 Steam Vacuum
Hoover steamvac gold-belt?
I have a hoover steamvac gold-model #f5887-900. runs but won't move.
probably a belt but i am not sure. if it is a belt: what belt would i need and how and where do i replace it?
thank you
  • 294 Answers
Do you mean the brushes will not spin? the most likely cause is the bearings have seized, it will need repair or replacement. check also the brush speed knob. when on, and handle tilted the brushes should rotate. There is no belt.
Posted on Mar 01, 2009
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not move any more how can I access the belt area to replace or inspect
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Please give positive feedback.
Mar 04, 2010 | Hoover STEAMVAC VACUUM Vacuum
Brushes do not turn
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Dec 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Belt broke how do i fix it
To my knowledge model F7220900 SteamVac doesn't require a belt. Are you sure that is your model? If you have a different Hoover model you can get a replacement belt here:
http://www.vacbelts.com/
Oct 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Belt Broke - Need to replace it
All you need to do is:
1) Get the actual model number of your Hoover. The information you gave is just what appears on the front of the unit, and that's not the model number. You will find the actual model number on a small tag at the rear of the vacuum near bottom, or on the bottom of the unit.
2) Take that model number to a local independent vacuum cleaner store (not a department / big box store, which will have very limited belt offerings), where they will set you up with a new one. Probably wouldn't hurt to call first just to make sure they carry them / have them in stock.
May 07, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover F5914 SteamVac Deep Cleaner
There is no belt on this model. what is your exact problem?
Nov 06, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover all terrain steamVac brushes wont move. Does this model have a belt and where
The brushes are driven by air flow (suction). the most likely problem is with the turbine. This part can be replaced or repaired. If under warranty, take it tin for service, otherwise you will void any warranty.
Sep 03, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hover gold steamvac 5 years old
Hoover steam vacs don't use a belt. may have a motor going bad. Having a model number would help tho.
Dec 02, 2007 | Vacuums
Hoover F5886-900 Steam Vacuum Logo
327 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
