Question about Maytag Washing Machines
Grinding sounds and smells of burning - Maytag Washing Machines
    Genius:
  • 1,028 Answers
Remove belt ..just lean back try turning pump by hand there is a metal shield on bearings it will sometimes drop down between pulley and metal frame causing noise and pump to bind..change 2 today for same problem
Posted on Sep 16, 2008
3 Suggested Answers
SOURCE: Grinding noise,unit stopped, burning smell?
Just had the repair man come out for the same problem....tranny gone, $600 to repair. Only 3 years old. Disgusted. Good luck.
Posted on Oct 13, 2008
  • 1937 Answers
SOURCE: Kenmore 80 series washer - making a grinding sound not agitating
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. The "burning smell" might be the rubber piece wearing
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Apr 21, 2010
My daughters 1991 Accura Integra (automatic) when placed in gear makes a loud grinding sound, the vehicle shakes and shutters when driving ?
ARE THE WHEEL LUG NUTS TIGHT! Poss Brakes grinding the rotors. Any burning smell? CK THOSE TIRES & BRAKES!
Feb 08, 2017 | Acura Integra Cars & Trucks
My maytag neptune dryer makes a grinding sound,and
I have no clue about the grinding but most likely the smell is burning lint. I'd recommend vacuuming out as much lint as you can. The better choice is open case and vacuum all of the lint.
Sep 12, 2014 | Dryers
My SUV makes a grinding noise and has a burning smell when I lift the hood. What could it be and how would I repair it?
Take the belt off, and see if that pulley wheel spins freely, If it is seized up, that is where the burning smell came from-belt was running across the seized pulley. If that wheel pulley runs the water pump, you will need to replace it.
Jan 16, 2013 | 1999 Isuzu Rodeo
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
I have a grinding noise near the back drivers side wheel it comes and goes sometimes whilst driving and driving at low speeds it also happens when i go round corners. There is a burning smell near rear...
Sounds like a broken bearing. If your wheel is beginning to wobble it will make contact with the brake shoes and this will them very hot to the point of giving off a burning smell
May 16, 2010 | Cars & Trucks
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Bad sounds, bad smells from 94 ford explorer
Sounds like you may have a vacuum line off or ruptured going to the EGR valve. The burning smell is probably the catalytic converter. When the engine runs rich you will get a sulfur smell that smells sort of like rotten eggs.
Mar 15, 2009 | 1994 Ford Explorer Limited
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
