Copier canon mf4150 says it has a paper jam, but there is no paper jam.
    Scholar:
  • 148 Answers
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Posted on Sep 16, 2008
Paper jam, followed instructions, paper tear as i removed from front of machine. paper not visible front or back. still shows paper jam. how fix please. tear approx in mid sheet?
Remove toner cartridge. You will find paper piece in there, I believe. Get ALL pieces out, put in fresh paper, restart. That usually does it.
Jun 12, 2015 | Canon imageCLASS MF4150 All-In-One Laser...
Canon printer MF 8080 cw will not reset after a paper jam
Hello, If the printer will not reset then you still have a piece of paper stuck somewhere in the paper path. Did you power the printer down and back up? Here is manual.
Canon imageCLASS MF4150 Manual
Sep 30, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
Our shop's Canon ImageRunner 3025 shows a jammed paper error, but there is not jammed paper in the copier that I can see. So what else could be triggering this jammed paper error? Thanks, Seth
You need not to pannic.Those paper jams are always there... What you need to do is to check you paper arrangement in papers tray sometime rough arrange may led to paper jams everytime
Thanks
Omari Saburi
Mar 04, 2011 | Canon ImageRunner 3025 Black and White...
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Got a paperjam. Pulled out the paper, but the paper jam error won't go away and the printer won't print. I read that it may be the paper jam trigger spring that is out of place now and requires...
No it's not. Make sure to open EVERY door on the printer and check for any additional paper. Also, power the printer off and back on a few times and see if it goes away.
Dec 24, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Nov 10, 2008 | Canon imageRUNNER 5570 Copier
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
CANON SUPER G3 IMAGE CALL MF4150
your printer needs to be reset.
Mar 15, 2008 | Computers & Internet
Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Jan 11, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
501 people viewed this question
jasbo
jasbo
