Question about HP Photosmart M425 Digital Camera
Camera hp m425
Camera won't work rightkeep saying batteries are low take 3-4 pictures
put new ones in does same thing
do it again it still says it's low
DARIO DI RUPO
  • Anonymous Oct 13, 2008
    same thing here
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Try using rechargeable batteries. I use Panasonic 850 MAH rechargeable batteries and they allow me to shoot alot.
Anyway this solution is cheaper than buying expensive batteries everytime.
Regards
Posted on Oct 10, 2008
    Master:
    Sergeant:
  • 462 Answers
Try quality batteries like Duracell or Energiser... and also make sure u give ample interval of 2-3min before each snap...
Posted on Sep 16, 2008
Dropped my camera and now the lens won't retract back in. When I press on the screen says lens error M425-12 (7f80). Can this be fixed and should I take it to a camera repair shop? Thanks
It could be one of two things, you bend the lens when dropped or the pins in the lens has become loose and are stuck.
You can try:
Taking the battery out for about 5 minutes and putting it back in to reset the camera. Also you can try hold the power button down and the ok or select button to to reset it. Also can hold the power and the menu button to try and force the lens out to dislodge the pins. If not,
The funny the is that I would have you drop it again on a carpet but on the opposite side to see if you can dislodge the pins from being stuck, try and have it land flat on its back from a decent height.
If the lens in bent you will have to bring it to a repair shop to have it fixed but it usually costs as much as a new camera.
Sep 06, 2011 | HP Photosmart M425 Digital Camera
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
I lost my HP Photosmart M425 USB connector.How do I get a newone
Consider getting a card reader instead. You should be able to pick one up at just about any department, electronics, or office-supply store for less money than a USB cable.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 07, 2009 | HP Photosmart M425 Digital Camera
Screen says "card is locked"
You have an sd card for this cam, depending on who made the card
there is a little white tab,or grey, on the side of the card, you can see that it can slide back and forth, and you should see the word lock,
just make sure the little tab is not on lock, slide it the other way.
You max card size is 2gig, and the first time you put in a new card you have to format the card with the camera.
Mar 16, 2009 | HP Photosmart M425 Digital Camera
How do i move pictures on my HP Photosmart M425 to my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 11, 2009 | HP Photosmart M425 Digital Camera (5MP,...
Can't take pictures, camera says it's in DOCKING mode
It sounds like you may have filled the memory car with pictures, and to continue to use it you must delete those which are on the card. I download my pictures to the computer and then I can delete them from the card and start all over again with taking pictures. I may have misunderstood your problem, if so please excuse me!
Sep 04, 2008 | HP Photosmart M425 Digital Camera
Lens error M425-12 (7f80) appears/ camera shuts down
yea.. i also got sand in my camera and i have thje same problem... there is no help anywhere on the internet for us :(
Feb 18, 2008 | HP Photosmart M447 Digital Camera
Wrong format on HP M425
Just fixed this problem on a M525 camera (same physical construction).
Do a search with M525 and format.
Feb 10, 2008 | HP Photosmart M425 Digital Camera
Hp photosmart m425 flash no longer works
I would look to see if wires are pinched going to the flasher.
You have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Dec 30, 2007 | HP Photosmart M425 Digital Camera
HP photosmart m425
can you help em upload videos?
Dec 08, 2007 | HP Photosmart M425 Digital Camera
HP Photosmart M425 Digital Camera Logo
97 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
