Question about Brother IntelliFAX 3800 Plain Paper Laser Fax
Print faxes in memory
After being unattended with a paper jam for a few days, the read out states there are 5 faxes in the memory - how do I get them to print out since they don't seem to want to come out voluntarily?
    Problem Solver:
  • 5 Answers
Slam it with your Fist, Hard! Kick the piece off the desk and jump up and down on it. **** on it!!
Posted on Sep 22, 2008
Wont print from fax memory
You may have a blocked paper sensor. Check the path the papaer would follow and located the sensors. Check them for dust or torn paper. The machine will not print until the jam error is cleared. If disconnected from power too long jobs in memory may be lost.
Aug 12, 2014 | Office Equipment & Supplies
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in...
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Oct 01, 2009 | HP 1020 Plain Paper Thermal transfer Fax
I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
May 13, 2009 | Panasonic Office Equipment & Supplies
L800 manual
You can download the user manual for this, just go to this link http://download.canon.it/manuali_operatore/files/L800ugen.pdf
Dec 02, 2008 | Canon FAX-L800 Plain Paper Laser
Memory RX, Recording Printing JAm
yes you can! if you really want it! you may enter the menu and in printing menu look for rx and press enter, or look for print from memory! it should work
Nov 03, 2008 | Minolta MF1600E Plain Paper Laser Fax
Alarm setting
The alarm sounds for only 5 seconds.When you receive a fax and the paper jams, the fax will be received into memory. When it has finished receiving the fax, the alarm will sound momentarily. When you remove the jammed paper, the fax will print automatically.
Feb 26, 2008 | Canon LaserClass 2060P Plain Paper Fax
Fax machine problems
I need to know if it still reads "paper jam?" If so, there must either be some piece of paper that is triggering the paper sensor, or the paper sensor actuator has become misaligned.
Feb 22, 2008 | Office Equipment & Supplies
Brother IntelliFAX 3800 Plain Paper Laser Fax Logo
76 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
