Question about IBM ThinkPad T23 2647 Notebook
Power fault could it be the power supply?
Has anyone come across this problems before? Currently my T23 ThinkPad has ben intermittently switching between the power supply and battery. One assumes that if I did not have a working battery then the unit would just switch off. It does it repeatedly for a few seconds then works fine on the power for 30 to 40 min. I am worried that this could damage the unit if it continues. If someone could help, I would be grateful.
  • pattijwoods Dec 13, 2008
    This is happening with my computer. I bought a new A/C adapter and it is continuing. Could something be loose "inside" the computer not allowing it to connect consistently?
  • 40 Answers
I would think the problem with loose connection from power adapter
Try another adapter
Posted on Sep 16, 2008
In my IBM T23 Thinkpad battery is fully charged showing green light constantly but not able to switch 'ON' after pressing the power button. What should I do?
try to switch it on with power cord still plug in it, if it do boot-up, you have to replace your baterry, if not somethings wrong with your laptop
May 06, 2010 | IBM ThinkPad T23 2647 Notebook
How do you dismantle a thinkpad?
though it at a wall NO lol, there are screws located on the bottom and back near hindges and under battery also under the keyboard, but start with bottom as there is one there that holds the keyboard on
Feb 12, 2010 | IBM ThinkPad T23 2647 Notebook
Spilled water on thinkpad t23 kybd
Hi, let it dry for a good few days, then try , hopefully it will; be ok.
Anthony
Jan 30, 2010 | IBM ThinkPad T23 2647 Notebook
Display drivers for IBM Thinkpad t23
Drivers for Vista are not available.
You can find all drivers for Windows XP{ and older clicking below:
IBM Thinkpad Driver Download models T22, T23
Direct link below:
T23 Video driver, v12.90.90
Mar 03, 2009 | IBM ThinkPad T23 Notebook
T23 Thinkpad turns off during boot after restart
My guess would be ;-
A power supply problem with the battery and/or power adapter
The most likely one.
The CPU is overheating and shutting down and if you wait a while and it will power it up again, it will then run for a while and shut down again.
This can be caused by a faulty fan (its not spinning and needs to be replaced) or the vents are clogged with dust (needs to be cleaned and you may need to remove the fan assembly to do this).
Jan 27, 2009 | IBM ThinkPad T23 2647 Notebook
When you power up the t23 2647 its vry very dark
Your inverter circuit board or its connectors/cables to display are fault. You should better take your laptop for repair.
Jan 13, 2009 | IBM ThinkPad T23 2647 Notebook
Battery/docking station ac power
There is no manual way to switch from battery to AC, the machine or docking station should automatically switch between battery and AC. There is a power management chip inside the laptop that regulates the power and switches from battery to AC when plugged in. Some docking stations have a chip built into them to do this. Start by ruling out the power supply. Do this by undocking the laptop and plug it in using the power supply that is attached to the docking station and see if the machine is just running off of battery. If it is running off battery, then check the power supply with an ohm meter for the proper output. The output readings are on the supply. If you have two power supplies, and you know one works with the machine, try that supply on the docking station. If the power supply checks good, then I'm afraid the pm chip on the motherboard has gone out. You will need to take this in to have it professionally diagnosed, because it could be a replaceable component that works in conjunction with the pm chip. However, if it is the pm chip, then the motherboard will have to be replaced in order to fix it.
Jul 22, 2008 | IBM ThinkPad T23 Notebook
No LCD Display, Does not Boot
I would check the power adapter with a multimeter first thing.
Nov 12, 2007 | IBM ThinkPad T23 2647 Notebook
Power problem
then the battery is not holding charge try leaving power cable in and switch on
Aug 22, 2007 | IBM ThinkPad T23 Notebook
T23 Thinkpad could not power up
Your machine should run without the battery, just plug it into the power supply. You may check the powersupply itself. Maybe the power supply was bad and not the original battery. You can pickup one at a computer store. A universal costs around $100.00 to $120.00. The power supply is the (usually) the rectangle box that is part of the power cord. Let me know if that was it. Good Luck. Tim
Mar 15, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T23 2647 Notebook Logo
50 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
