Question about HP 1010 Plain Paper Inkjet Fax
Fax locally but not long distance
I can fax to local numbers but I can not fax to my home office in atlanta or to their (800) number
  • 2 more comments
  • hollynoell1 Sep 17, 2008
    okay so how do i get it to fax long distant...att said that it wasn't anything on their part?
  • hollynoell1 Sep 18, 2008
    Thank you for your help!
  • akivas Feb 16, 2009
    My problem is that I am not able to receive long distance faxes. Help!!!!!!!!
  • Anonymous Apr 21, 2009
    I belelive it may be your machine. I have the same problem but if i can recive just fine from long distance from another fax on the same line.
    Genius:
  • 2,120 Answers
Your long distance access is denied.
Posted on Sep 16, 2008
  • Leroy Elliott
    Leroy Elliott Sep 18, 2008
    Well, I don't know the answer, however, i.m convinced it's not your machine.
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
Jun 12, 2012 | Brother IntelliFAX 1840C Plain Paper...
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
When I try to send a fax to a 800 number or long distant, it dials and picks up then does that sound thing it does and then cuts off. The error says fax info does not match... the number is correct and we...
Does it work with local phones or is the problem only with certain places yo try to fax to? If it does, then there may be an incompatibility problem with some remote fax machines.
Jan 07, 2011 | Canon PIXMA MX310 All-In-One Printer
I need the instructions for the mounting bracket for the stoney point bipod.
Contact them at the appropriate number listed below:
hope this helps, Mark the Gunsmith UNITED STATES
Bushnell Outdoor Products
9200 Cody
Overland Park, KS 66214-1734
In Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
CANADA
Bushnell Corporation of Canada
25A East Pearce St.
Richmond Hill, Ontario L4B 2M9
Local Phone - (905) 771-2980
Other - (800) 361-5702
Local Fax - (905) 771-2984
Other Fax - (800) 661-3254
Dec 25, 2009 | Stoney Point Optics
I can fax to local numbers but not to long distance numbers. Phone company has no clue.
Your problem is how you have set up your long distance carrier. You may not be able to use your fax if you must first go through a phone card system. However, sometimes you can use enough pauses in your fax dialing to get through it. If your long distance carrier is your local phone company, they SHOULD be able to tell you how to dial.
Oct 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
We are having problems with our Muratex F110 fax machine. It won't send long distance faxes. the phone company says it is not on their end. any suggestions?
Well technically it's not on thier end. Let's remember that a fax uses a normal home style phone line.
So ask yourself these questions.
#1 Do I have long distance service on this phone line?
#2 If I do have long distance service do I need to do any kind of special dialing sequence to access long distance? Like a 9 or an 8 or any other number before dialing outside of your local area.
In some cases( businesses usually) a special code needs to be entered after dailling the number.
Most fax machines have a hansdset on them. Do this simple test. Lift the handset and dial a known long distance number and listen to what the operator message says. If all else fails call your phone company and ask them if this line has long distance capability.
Sep 22, 2009 | Muratec Office Equipment & Supplies
Brother IntelliFax 4100 will not send long distance
it must be a problem with yourphone line. Contact your phone company, this can be solved at their level.
Jun 02, 2009 | Brother IntelliFAX 4100 Laser Fax
When I try to fax, my home phone rings and I get a fax error
don't dial your home phone number when you are trying to send a fax
and stay of the booze
Apr 16, 2009 | Lexmark X6150 All-In-One InkJet Printer
When I try to fax there is a beeping sound. the report says the line is busy/noresponse
i would first reset up the machine in send and receive mode, is there dial tone. let me know what happens
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
No longer dialing Lond Distance
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Apr 04, 2007 | Smartlink (I56KSPF00) Modem
HP 1010 Plain Paper Inkjet Fax Logo
873 people viewed this question
Ben Johnson
