Question about RCA HD52W59 HDTV Projection Television
My tv powers off when I turn it on
Everytime I try and turn my television on it powers right back off, the green light comes on then goes off, why is this happening and what can I do to fix it; thank you
  • Anonymous Sep 23, 2008
    Im having the same problem but my TV is a 60inch.
  • Anonymous Oct 01, 2008
    tv shut off while waching wont turn back on greenlite just blinks badcocks kept my remote after a repair but says its still under warrity
    moved from the area of that store
    Genius:
  • 1,139 Answers
Hello aeasterling and Guest,
This might be caused by a short circuit in one of the components in the LV or HV power supply. I would first do a visual inspection to see if I see and damaged components (burnt transistors or resistors, puffy or blown up capacitors, and burnt transformers). If there are no visual signs of trouble, I would then begin troubleshooting the TV with a schematic and a multimeter (on the resistance setting) "REMEMBER HAVE THE SET UNPLUGGED" for these tests What I would be looking for are shorted or open components (mainly the power transistors and or FETs, transformers, capacitors and inductors). Then with the power on and the multimeter set to voltage measurements, I would perform tests to see if the proper voltage levels were present at the proper test points.
However if you do not have a background in Electronics I would suggest that you take the TV to a qualified TV repair shop.
I hope this Helps,
Thank you,
Shuttle83
Posted on Sep 28, 2008
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
When i turn my tv on the red light goes to flashing green it comes on then immediatly it goes off but the light is on green... can you help
Tries tv unplug,replug it back about an hour later.The tv,now should reset itself back to factory setting.The tv should work now,not than the power supply board is dying,not giving the right voltage to the rest of the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | LG 42LG30 42 in. LCD HDTV
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
Stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
May 16, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
