Question about Epson Aculaser C1100 Printer
Epsom dx4450 how to change ink cartridge
Printer
    Scholar:
  • 148 Answers
Replacing the cartridge:
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
Posted on Sep 16, 2008
  • kathjohnson9 Feb 05, 2011
    It frequently takes several goes at pressing for 3 secs before the cariage finally comes to rest to enable exchange of cartridge.
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
Changed ink cartridge ,but still says Ink cartridge need changing
after 3 or more charges the cartridge goes useless... buy a new set and try.... good luck
Oct 19, 2012 | Epson Stylus DX4450 All-In-One InkJet...
How do I change ink cartridges for Epson DX4450
Jun 07, 2011 | Epson Stylus DX4450 All-In-One InkJet...
Replaced all ink cartridges with epsom cartridges. Printer shows ink incompativble- replaced with identical cartidges and printer wont print
the inks u had replaced might not be the compatible with ur printer you need to change another inks which are compatible only
Jan 26, 2011 | Office Equipment & Supplies
How to persuade my epsom stylus DX6050 printer to accept non epsom ink cartridges
i have a continious ink setup on epsom dx5060 system is telling me to change the cartridges they have reset chips in them????
Jan 21, 2011 | Epson Stylus DX6050 All-In-One InkJet...
How to change ink on a epsom stylus 215 printer
Hi Eileen!
Use the instructions here to change your printer's ink cartridges.
(Use the arrows on top to switch pages until you get to "Remove and Install Cartridges").
Best regards,
Pelu.
May 10, 2010 | Epson Office Equipment & Supplies
Replace ink cartridge
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Have a nice day and do not forget to rate please...!
Feb 16, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Hello i changed the ink in my epson stylus dx4450 however the ink light is still on and it still wont print. i tried turning it off at the plug but still wont work
It seems that the connection on the cartridge and the printer are not proper. Remove the cartridge and clean the connectors on the cartridge and the printer. Also remove the tape on the print head.
Aug 28, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Ink cartridge
The access door for the cartridges in on the front right corner of the printer. Put your hand on the side of the printer, (Just around the corner), you will feel a spot to put your fingers to pull down the access door. It is well hidden, what where they thinking? From there it is really easy to just pull down the printer doors and change the ink cartridges.
Good luck to all!
Tracey
Apr 28, 2008 | Brother Multi-Function Center MFC-240C...
Epson Aculaser C1100 Printer Logo
322 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
