Question about Xerox WorkCentre Pro 412 All-In-One Laser Printer
Installation of a Xerox workcentre pro 412
Hi,,,
I get a Xerox workcentre pro 412 but I don't have a CD to get it installed, I've been trying to get some one free at the internet,,, could you help me please?
Thanks!
Rossy
  • Anonymous Mar 12, 2014
    xerox pro 412 dead
    Scholar:
  • 148 Answers
download the driver on the link here ABOVE.
Posted on Sep 16, 2008
Is there an on/off switch for the Workcentre pro 412?
there is no on/off button for this machine however for more features try THIS link for user manual
Nov 15, 2011 | Xerox WorkCentre Pro 412 All-In-One Laser...
I look for CD Driver for Xerox WorkCentre Pro 412
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
Nov 14, 2011 | Office Equipment & Supplies
How do I scan a photo onto my laptop using a Xerox WorkCentre Pro Scanner?
Just attach the scanner to your laptop.Install the drivers of your scanner into your laptop and restart the laptop.
Now start scaning your documents..
Regards,
polysandy
Apr 06, 2010 | Xerox WorkCentre Pro 412 All-In-One Laser...
I have a Xerox WorkCentre Pro 412 and it will not power up.
First and most simple. Plug something else into the outlet to make sure it works. If this model has a removable power cord then try re-inserting the cord. While you are there and with the cord installed, lift up then push down slightly and see if it comes on. If the power cord is removable the receptacle where it plugs in are notorious for breaking the solder connections. If this is the case it just needs to be re-soldered. If the outlet is ok, the cord is ok or hard wired in then you may have either a blown main fuse or a bad power supply.
Good Luck
Nov 30, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Xerox workcentre pro 412 printer do not work
i changed the usb cable to anthor one Parallel Port
Cable so i think the adapter of usb cable is damaged so now it work.
Jul 06, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Describe your Xerox WorkCentre Pro 412... Problem:Scanner
Turn off the copier first.
Look under the copier, there by where the copies come out, look just above that portion of the machine. There will be a green sliding latch; one side has a picture of a pad lock for lock, the other side has a un-lock position, slide the latch to the unlock position.
Turn on the copier, and the machine should work.
That latch is for transporting the copier when being moved. It will hold the scanner in place so it does not move around.
Apr 23, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Xerox Workcentre M940 lost CD
Call, 1-800-828-5881 then follow prompts 4 then 3. They should be able to look that up and order you the proper disks. If not they will direct you to who can.
Jan 03, 2008 | Xerox WorkCentre M940 InkJet Printer
Xerox WorkCentre Pro 412 All-In-One Laser Printer Logo
547 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
