Question about Dryers
My gas dryer Maytag mdg7057bww blows air but no heat. How do I get into it to check it out? Can I go in thru the front or back? Thanks, B
5 Suggested Answers
SOURCE: gas dryer lgr 8648
Found the coils. Had to pop off the entire front panel. They were then easily reachable.
Posted on Jan 19, 2009
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
ftw1952
  • 10319 Answers
SOURCE: my maytag model mdg508daww gas dryer heated up for
the sensor for the burner is at fault
Posted on Feb 15, 2010
iwillfixforu
  • 619 Answers
SOURCE: maytag gas dryer will heat for about one minute
The gas coils on the gas valve have gone bad. These are located on the gas valve and will be 2 solenoids. Replace them both and should be able to get as a set. 12001349 should be the number and cost less than 60.00 for the set. Good luck and thank you for using Fix Ya.
Posted on Feb 24, 2010
  • 4 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Maybe that was in addition..they tell us the air flow is blocked and tell us 2 clean our air duct ..but the dryer was blocked on inside..the repair man claimed the belt was off maybe he was blowing smoke..but these are the kind of people they are sending out..trying to blow off as many appointments so they can get off on time.
Posted on Jul 26, 2011
The dryer rattles in the motor area also the dryer takes a long time to dry.
You have a bad blower . This piece slides onto the motor shaft and pulls the heat thru the drum and out thru the vent hose . It is easily replaced ( and inexpensive if you do it yourself ) by removing the front of the dryer .
Mar 20, 2011 | Maytag Dryers
Dryer spins,screen clean,exhaust open blows good no heat
Check the coils on valve or the igniter. Access both thru Access panel on lower right of front panel. Set heated dry cycle & start, igniter should glow bright followed by a "Click" sound, which is valve opening. If it glows and no click, replace the valve coils (2 donut looking objects on top of valve). If no glow, replace igniter, usually just unplug to remove, carefully, they are ceramic and break easy.
Feb 13, 2011 | Maytag MDG2600BWW Gas Dryer
Not heating blows cold air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer runs but no heat.maytag neptune gas dryer.
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Maytag Dryers
My maytag front load dryer turns on and runs,it does not blow any hot air
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat in gas dryer, gas good, elec good??
if the heat is on when the dryer is cold then shuts down after 15 to 30 minutes and doesn't lite for a long while you have bad gas coils,the gas should come on until it hits temp. then it shuts down,when the dryer calls for heat it will turn back on,if it stays on for short periods of time you might need to clean out the dryer,this will shut the gas down to soon,you need to clean out the duct that the lint filter slides into,blow out the vent line,make sure the air is blowing outside with nothing blocking it and vac out the inside of dryer where the motor is
Mar 12, 2010 | Maytag Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
My Maytag Altanis Gas Dryer, does not heat for the whole cycle.
replace your gas valve. not opening up completely. check wires for good connection inside the male and female harness
Jun 22, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag MDG16PR gas dryer produces only warm temperature
you could have a blockage of lint either in the dryers front bulk head (where the lint screen is) or you could have a blockage somewhere in the vent line. check those and if you have a blockage remove it and that should clear up the problem
Oct 20, 2008 | Maytag MDG16PR Gas Commercial Dryer
Dryers Logo
248 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
