Question about Toshiba 1360 Black and White Copier
Toshiba 1360 Copier
The wrench light comes on and i get a C7 code. we have had this problem before and we reset it, but i cannot find my manual. can you tell me how to reset the copier?
thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
"C7" Faulty thermistor, thermal fuse, or heater element
Posted on Sep 16, 2008
What does an error c7 means in toshiba photocopier 1360 ?
C7 could be nothing serious but it had to of happened three times before it quit resetting itself, which means it has happened to you before. This model has a tendency to throw this code for no real threatening reason, but it is there as protection for the copier and it's environment. You really should have a tech look at it for you, and not just reset it.
Switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
Sep 24, 2015 | Toshiba Office Equipment & Supplies
Toshiba 1360 C7 code. How expensive is it ti fix
With the unit off hold down clear/stop and 8, ad should apear push 89 start (display will read 03) then 0 start. tis should fix it. -Carl
Jun 11, 2010 | Toshiba 1360 Black and White Copier
Toshibe Copier 1360, Error light
you need service technicien to maintenance your copier, because it is full with used toner.
Nov 17, 2008 | Toshiba 1360 Black and White Copier
Wrench light on and c7 code appear
C7 is a Fuser Error......The hot part where the paper passes through before exiting the machine is known as the Fuser or Fixing unit etc.
There are 3 parts involved and any of which when they fail will give a C7 error code. The Heating Lamp,Thermisor or Thermal Fuse.
This is a live area of the machine so you wouldnt be advised to attempt a repair without at least a restricted electrical license.
More than likely one of the parts mentioned will need to be replaced and then the C7 error count reset through "08"
May 12, 2008 | Toshiba 1370 Black and White Copier
Toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
Mar 18, 2008 | Toshiba 1360 Black and White Copier
Error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
Oct 26, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Oct 25, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Oct 22, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 Black and White Copier Logo
488 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
