1) If timer dial does not rotate, then clock motor is not getting electricity, or clock motor is bad.
-Make sure time dial is seated correctly. Pull it off firmly and then push in firmly.
-Check circuit breaker is not tripped.
-Test across terminals 1 and 2 on timer for 240Volts.
-Test terminal 1 to ground and then test terminal 2 to ground to make sure each hot wire from breaker has power.
-If circuit breaker is tripped on one leg, the timer can appear to have power, but is only receiving 120V and not the full 240V, so the time dial will not rotate.
-Look for signs of high heat and burning.
-Check that no insulation, and only copper wire are under the screw-down terminal plate.
-Make sure that same gauge wire is used, and that stranded wire and solid copper wire are not under same screw-down terminal plate. The stranded wire will come loose.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/pdf/wh21-manual.pdf
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html#fire
2) WH21 is rated for 25 amps and has 1 year limited warranty:
If label on side of water heater shows rating of 5500 watts, then divide by 240Volts = 22.91 amps.
4500 watts = 18.75
http://www.intermatic.com/customer%20service.aspx
3) Replacement clock motor is not shown for WH21 timer.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#clock-motor
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
