Question about Archos Gmini XS200 MP3 Player
Burnt out recharger, circuits blown
Hello, I doubt whether you can help, but I noticed your site when I was googling for information about Gmini XS200. My recharger unit burnt out one day and the MP3 player doesn't work, so I think it damaged the circuitry. Actually, it could have caused a fire, when I found it the charger was giving off black smoke. I bought another MP3 player which isn't as good as the Gmini and just left it. Wondered if I can do anything now?
I'll probably write to the manufacturers, see what they say
my email is
2 Suggested Answers
SOURCE: My Archos Gmini XS200 does not fully charge any
ebay have ads for replacements.
remove the back cover by taking out the 4 screws , fold out the hard drive unit and you will see the battery under it.
unsolder the two wires - positive and negative- ( red and black )
solder on the new battery wires in the correct place and re assemble unit .
Posted on Dec 27, 2010
Amana dryer model ned4500vqo doesn't stop at end of cycle . It is not clogged I changed the thermal switch cause it burnt up please help need to know what to replace
you may have a faulty controller circuit board. you will need to get some information on troubleshooting or replacing the board. try google or use amana's web site and tech support.
Jun 04, 2014 | Dryers
Channel A on my PMP 1280s is blown
This website appears to have diagram for it. You will have to register to log in.
May of been some other component burnt out. Only way is by test meter and testing. Quite possible transistor burnt out.
You should be able to test it in circuit for Short circuits.
If output transistors faulty make sure you check driver transistors as well. Hope some of that helps.
Nov 19, 2013 | Audio Players & Recorders
ECU Fried? 2004 toyota highlander.
Hello! The circuit is protected...First by a 12 GA Fusible link (White)...It feeds two other fuses a 30 Amp and a 140 Amp...I doubt the link is burnt open but those other two fuses are more than likely blown...Follow the positive cable to the box...Guru...saailer
May 07, 2012 | 2004 Toyota Highlander
How easy is it to repair a POWER FAILURE TO SONY KDL-32S3000 TV
Usually it takes a little knowledge of basic electronics and some soldering skills. If you have these, then it never hurts to try to fix it yourself. Its already not working. Just make sure to work safe, unplug before working on it and close up before turning on. If you think its a power supply you might be able to see some blown capacitors, or you might get lucky and find a blown fuse inside.
Hope this helps
Jan 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
Win98 asking for driver of cruzer blade
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
Whether there will be a driver for WIN98 I doubt as Cruzer Drives were not about in 1998!
I hope this helps.
Dec 29, 2010 | Computers & Internet
Burnt out power board
I sympathize with your problem, but I think you are knocking at the wrong door. You should contact your local Packard Bell dealer.
Hope it helps
Aug 28, 2009 | Computers & Internet
On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you:
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Dec 11, 2008 | Office Equipment & Supplies
The power randomly shuts off, will not stay on
I think squeezing the casing back together works... it did with mine. For a while anyway, I have yet to see if it lasts.
Jun 21, 2008 | Archos Gmini XS 100 MP3 Player
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
May 22, 2007 | Archos Gmini 402 Digital Media Player
Archos Gmini XS200 MP3 Player Logo
51 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
