Question about Sanyo DS20930 20" TV
Converter boxs do i need a converter box for these sanyo models DS19130 DS25530 thank you for your help
  • dwhj1125 Sep 16, 2008
    still needing an answer thank you
  • 4,234 Answers
If you have cable or satelite service, no converter is needed for either one. The only time a converter is required is if you receive the TV signal from an antenna (over-air). The DS19130 WILL require a converter for over-air broadcasts. I think that the DS25530 will as well, but I am not 100% sure. Because of its age, I would suspect that a converter will be required for hte DS25530.
Dan
Posted on Sep 16, 2008
I have a RCA Converter box. ATSC mfg Dec 2010. I need the access code for the tv I am hooking up this converter box too. Sanyo Television. Thank you
Hello
Try these links.
tv.manualsonline.com/.../rca/...converter-box/remote-instuctions-213
Try these codes too:
037, 082, 083, 124, 198, 268, 274
http://www.dataentryjobs.us/67948.html
Feb 08, 2012 | Televison & Video
I have a Sanyo Model number DS25530 that has a Flickering Screen
well sounds like vertical issue take to tv shop vertical ic or bad caps
Apr 03, 2009 | Televison & Video
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Do I need converter for Sanyo DS24424A manufactured in 2005.
hiya
what you may need is a freeview box unless ur tv has in built digital
rik
Feb 24, 2009 | Sanyo HT27546 TV
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
No real problem yet
yes,,,ur TV is a digital one...
Jan 28, 2008 | Sanyo DS25390 TV
Need converter box
Not if you have cable TV, satellite TV, or FIOS. If so, a converter won't do anything for you. Not needed.
If, however, you only use a regular TV antenna or rabbit ears, you will need a converter box as this model TV only has an NTSC analog tuner built in.
Jan 04, 2008 | Sanyo DS24425 24" TV
Sanyo television-model-DS25530
have you treid the menu settings and looked at the rear for internal /external switch on the rear of set if yes to both possible audio ic.
Aug 14, 2007 | Sanyo AVM-3259S TV
Sanyo DS20930 20" TV Logo
96 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
