Question about Adobe Illustrator CS V11.0 for PC
How to set parameters for the bounding box - Adobe Illustrator CS V11.0 for PC
  • 82 Answers
A bounding box will always be the size of the thing it is "bounding". I think you may be talking about the selection tools Rectangular marquee.
Once you clicked on that selection tool at the top you can change it from normal, fixed aspect ratio, or fixed size.
Fixed aspect ration will just go equally. As in the x and y size will grow proportionately
fixed size will make the selection however big you want it. As in always 6" x 8".
normal is...normal. However big or small you want it
Posted on Dec 02, 2008
I use KEB 18.F5.CBG340A (22,0 kW) "Compact"inverter , to run this inverter whose parameter must be set from cp mode and application mode
The CP mode parameters are a small list of parameters that are mapped from the application parameters. Not knowing what you are trying to do with the inverter, it is very difficult to tell you what needs to be programmed.
90% of the machines that us the KEB inverters use the application parameters to gain the full functionality of the inverter.
The machine manufacture whom built the machine that the inverter is installed in should be able to provide you with parameter settings.
There are instruction manuals on the KEB site.
www.keb.de
www.kebamerica.com
Sep 04, 2013 | Inverter KEB COMBIVERT F5
Factory reset of lg 32lc2d
Hello
you want to reset all parameters of your TV to Factory default, I assuems and posts this solution.
1. Press the "Adjust" button on the remote handset; press "Up" or "Down" button to select the "Reset" option.
2. Press "Enter " button and Use " >" or "<" button to select "Yes".
3. Press "Enter" button.
All parameters will be set to its original Factory Defaults.
Feb 06, 2012 | LG 32LC2D Television
What is the main advantage of watermarking
This paper presents both theoretical and practical analyses of the security offered by watermarking and data hiding methods based on spread spectrum. In this context, security is understood as the difficulty of estimating the secret parameters of the embedding function based on the observation of watermarked signals. On the theoretical side, the security is quantified from an information-theoretic point of view by means of the equivocation about the secret parameters. The main results reveal fundamental limits and bounds on security and provide insight into other properties, such as the impact of the embedding parameters, and the tradeoff between robustness and security. On the practical side, workable estimators of the secret parameters are proposed and theoretically analyzed for a variety of scenarios, providing a comparison with previous approaches, and showing that the security of many schemes used in practice can be fairly low.
Mar 19, 2010 | Computers & Internet
When i attempt to differentiate an equation, the answer is a matrix, how can i get it back to normal, and get the actual answer?
I do cannot see how you can go from a scalar to a matrix. The only possibility is if your expression includes parameters , say A, B, or some such things that were previously defined as matrices.
If you had at some time defined a matrix (A or a) , have forgotten about it, and now you are using the symbol (A or a) as a parameter in a function you are trying to differentiate, the answer is bound to be a matrix.
I suggest you run the NewProb command, or in HOME folder, press [2nd][F1] (F6) [1:Clear a-z] [ENTER][ENTER]
I am no seer and I may have guessed wrong. If you still want to solve your problem, post a comment giving more information.
Jan 23, 2010 | Texas Instruments TI-89 Calculator
How to use NumSolve on the Casio Classpad 330 Calculator Also is there a way to get back a deleted e-activity document?
Sorry the solution was posted as a clarification request. Here it is at the right place.
  1. Turn calculator ON.
  2. Look for the NumSolve icon.
  3. Tap the icon.
  4. The equation editor screen opens with the word Equation: on one line and a small rectangle on the next one.
  5. At the position of the rectangle, type in the equation.
  6. Do not forget the right hand side.
  7. Press [EXE].
All the non-numerical variables, parameters are then listed with a radio button next to each one of them.
  • Tap the radio button next to a variable and enter a value for a parameter.
  • Repeat for all known values.
  • Last, enter a guess for the unknown you are solving for and
  • set the bounds between which you suspect the solution to be.
  • While the radio button for the unknown is still checked, tap the Solve Menu at the top of the screen,
  • select Execute submenu and
  • press [EXE].
  • Alternatively you can tap the Solve at the left of the toolbar.(see picture).
If all goes well and the solution is found (this dependent of how good your guess is), the calculator returns with the value of the unknown and displays the difference
Left side-Right side = 0 or a very small number.
If the solution cannot be found you will be prompted to change the initial value (your guess) and/or the bounds. Hope it helps.
Nov 27, 2009 | Casio ClassPad 300 Calculator
Cannot re-set network configuration.
Try 6482 or MITA as password
Try leaving password box blank
Try entering the IP address in the web browser and configure there. The firmware will have to flashed if this doesn't work.
Kyocera is pretty picky about resets. You might have to phone them.
1800-GET-MITA
Feb 24, 2009 | Kyocera Mita FS-1920 Laser Printer
Send/receive
Go to menu Tools -> Send/receive-> parameters -> send/receive parameters -> define and check the box to automatically send/receive. Adjust the delay (30 minutes default, 5 is Ok, 1 is too much for the remote server)
Feb 17, 2009 | Microsoft Office Outlook 2003 for PC
Can call forward outside system be programmed from the user handset on a comdial fx ii impact system?
I do use CFOS, but to get it working, I did have to do some system programming. You have to turn on the master CFOS enable system parameter, and you have to assign a button for the station to be a CFOS feature button in the Station programming screen. The outside number to which calls will be forwarded is also assigned on the same screen... I've never found a way to set the number from the station itself.
Oct 08, 2008 | Comdial Impact 8024S-PT Corded Phone
Panafax dx-800
Press Function, then 7
Press 4, then Copy/Set
(it should ask for a fax parameter, the one for the key sound is 010)
Enter "010", then Copy/Set
Set the parameter to "1" for Off, then press Copy/Set
Press Stop to exit back to the default screen
Jul 23, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Adobe Illustrator CS V11.0 for PC Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
