Question about RCA TruFlat 27F520T 27" TV
Rca 27410tyx1 will not shut off
For the past 2 months i will shut tv off (either by remote or front button) it will power off then come back on after about 2 seconds. yesterday it was on and shut itself off, now it will not turn back on.i can hear a high pitched buzzing.
    Scholar:
  • 188 Answers
Sounds like trouble in the standby/power up circuit. have you tried unplugging the TV for a half hour and seeing what happens? It might start up but I think this problem won't go away. If you heard a high pitched buzzing it sounds like a problem in the high voltage not letting the start up circuit work. threy are related. The start up circuit waits for the high voltage to stablize and then switches it on.
Posted on Sep 16, 2008
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Hello I have a universal remote control for tv sanyo but I lossing de manual instruction and Iand ree program my tv. only I need how cam progarm my remote control pleaswed thanks.
Here is the steps on how you can reprogram your RCA tv remote control:
1. Turn the television on by pressing the "Power" or "On" button that is located on the set.
2. Press and hold down the "Code Search" button located on the RCA TV remote. 3. Press the "TV" button on the RCA TV remote. Once you press this button, you can release the "Code Search" button
4. Start pressing the "On/Off" or "Power" button that is located on the RCA TV remote. Keep pressing the button until the television shuts off. 5. Press "Enter" on the RCA TV remote to save the code on the remote. The remote will then control the television.
Apr 07, 2011 | RCA Universal Remote Control
Locked tv set model f19421
These are the instructions on locking and unlocking the control panel for your TV: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 12, 2010 | RCA F19421 19" TV
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
I enabled the FPA lock on my RCA 20f511T and it shut off. Now I can't turn it on with the panel on the TV or the remote.
Disconnect the power cord from the outlet for AT LEAST 30 MINUTES, that should cause the TV to reset back to factory default settings, then you can start over with initial set up,etc, after you restore power to it.
Jan 31, 2010 | RCA 20F420T 20" TV
How to put cod in rca remote. for rca sdtv
press tv button, then press and hold setup button, then press power button several times until tv shuts off. As SOON as it shuts off, press enter.
Jul 05, 2009 | Televison & Video
Hi, I have a problem with my rca television model number RCAS01BA. My dauther has somehow put the child lock on without using the remote control as we had lost that a couple of months ago. (God bless...
You don't need the remote to unlock the TV. Any RCA universal remote will change channels etc if you want a remote.
Now from the manual: simultaneously hold down the menu/OK button and the Volume down button for 3 seconds. This resets the pasword and unlocks the TV. You can then enter the menus as usualI believe to control/clear parental settings etc.
May 22, 2009 | Televison & Video
Rca remote
Finding a code for one TV could take a long time, here's what you do
1. Press the TV button once 2. Press and hold "Code Search" until it lights up 3. Point the remote at your TV with the TV on, and keep pressing the power button until the TV shuts off 4. Press the TV button once more.
Jan 21, 2009 | RCA Universal Remote Control
Front Panelbuttons
You probably should replace the button matrix. They are usually less than $20. You do have to take off the back of the set ( makes sure its unplugged) It's also possible that the switch has collapsed, whoch can be replaced but needs some soldering skill. Google RCA parts or try herman electronics. You will need your model number to get the correct parts.
Aug 06, 2007 | RCA F32650 32" TV
RCA TruFlat  27F520T 27" TV Logo
93 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
