Question about Dell 3100cn Laser Printer
004-321 restart printer
I got the same error evry time i start the printer
  • 6 more comments
  • Anonymous Oct 09, 2008
    Exact same issue here. Everytime we turn it on it just says to restart it again. No printy = no happy.
  • Anonymous Oct 20, 2008
    Bonjour, j'ai le même problème. Doit-on changer le tambour de l'imprimante ?
  • Snapstinget Oct 31, 2008
    Suddenly stopped printing mid-job to give me the same error message. Have restarted lots of times - same message.
  • taskgroup Dec 12, 2008
    CANNOT GET PAST THE ERROR MESSAGE TO RESTART THE COMPUTER.
  • Anonymous Jan 16, 2009
    i tells me to load mpf letter plain 1 024-969
  • Anonymous Feb 25, 2009
    After hooking up and installing printer to a new computer it shows error message 004-321. I have removed the drum and all print cartridges, wiped down all the toner from any surfaces, cleaned sensors where indicated to me by Dell and still I am getting the same error. Dell suggested I buy a new printer. Any other ideas???
  • Anonymous May 18, 2009
    Error code 004-321/restart printer. Drum belt had worked its way to far left. I centered using the fix posted above. Worked great. Thx gonlgonl, & Thx elwood for photos.
  • Select Cartridge Feb 03, 2012
    it worked, great, thanks
YES! It Worked. Man I love it when things like this work out! Thanks Gnolgnol!
Let me just elaborate however:
The "belt" is the 8 1/2" wide black rubber piece wrapped around the drums located at the back top section just near the 4 black arrows and "no hands" warning picture. I was too lazy to unscrew it to fix it so I simply used much force with the palm of my hand and rolled and pushed up and over in the direction it needed to be adjusted several times. The belt will overlap on both sides about 1/8" on both sides so make sure you go past the drum a bit to even it out on both sides.
Posted on Mar 27, 2009
First take out the drummer, there is a belt in side make sure that it is the CENTER , if not remove screws and center the belt. this sure work. hope that's help.
good luck
long
Posted on Nov 29, 2008
  • gnolgnol Dec 09, 2008
    first take out the drummer, there is a belt in side make sure that it is the CENTER , if not remove screws and center the belt. this sure work. hope that's help.
I have erorr 004-312 and 004- 321in dell 3100cn laser colour printer
Posted on Sep 25, 2008
What elwood7771 said WORKED!! Thanks for the pics. Just push the black rubber using your palm or fingers to center the rubber sheet. This shuold fix it.
Posted on Apr 22, 2009
Bonjour
mon imprimante presente une erreur 004-321
je ne sais pas comment la resoudre
et comment reconnaitre une cartouche de tambour endommagée
merci d'avance
Posted on Oct 20, 2008
Thank you so very much for this fix...it WORKED! Perfectly.
Posted on Sep 18, 2015
The CD tuner
What does your owners manual tell you about that error code .
Sep 13, 2015 | Cars & Trucks
Y - CRUM Error / Error 093-950 Restart Printer
093-950 Y - CRUM Error
Error 093-950
Restart Printer
The yellow toner Smart Chip error is detected
Error with detecting or defective yellow toner cartridge. Replacing cartridge should correct it.
Paul
Nov 25, 2013 | Lexmark X560n Laser Printer
Crash evry time im open it
Click Start
Click Control Panel
Click Add/Remove Programs
Click to select Google Chrome
Click to Uninstall it
Restart your computer
Reinstall Google Chrome
Mar 18, 2011 | Google Chrome
My aspire one netbook dosent have java evry time I download it it sais it wasnt downloaded properly please help from, Doug
repair ur system files, clean ur pc, uninstall java, delete its registry key and then restart pc, download reginout to cleaner errors, then download java, download it from official site of java
Aug 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
The paper gets blocked evry time i start the printer
It could be that small pieces paper is still stuck in the rollers. Make sure also that the paper feeder is properly placed on its correct location. Other things you can do is to put some more paper on the tray. See if it will feed the paper.
Please post back if you still have any concerns.
Aug 21, 2009 | Samsung ML 1710 Laser Printer
I cant repair my riso
Need proper error code.. A letter should come before..
Apr 29, 2009 | Riso RZ220 Duplicator
Lap top wont boot up
Go to the BIOS menu and select the Main Tab... see if the computer sees your drive. If not send it to the manufacturer or look to see if you can get to the HD without cracking open the main case to the laptop
if you can... check the connection from the HD to the connectors to the motherboard
Apr 08, 2008 | Computers & Internet
Dell 3100cn Laser Printer Logo
5,316 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
