Question about Sewing Machines
Hope someone can help me with this problem!!!!
Hi ,
I'm fifi1076, and I'm having quiet a good bit of trouble with my sewing machine.
I'm new at this site so I don't know if I'm doing this correctly or not so please
forgive me if I do something I'm not suppose to do!!!!
I have tried everything I know to do in order to get the bobbin to tighten up!!!
I have sewed five different times on a scrap piece of material and tightening up the bobbin each time and each one of those times never did show that the bobbin tightened up not even a tiny bit!!! I went and ordered another bobbin case for it!!!
If whoever can help me with this and can give me a solution I will be forever gratefull
Thanks,
Kay Nowicki
  • fifi1076 Sep 16, 2008
    Hi Sewman7,
    Thank you thank you thank you!!!!!!
    I'm so releieved for you helping me!!!!!!! Can I use this program in answering my questions especially about my sewing machine problems.....without having to pay for it?
    I will be willing to pay for it after I get some of my bills paid off!!!
    Thanks,
    fifi1076
  • 323 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try This. It should solve your problem
Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Sep 16, 2008
Manual
I hope that someone has a better answer than me. I have searched the internet for "Highland"sewing machines without any hits at all.
Attached link is to youtube videos about threading sewing machines.
Your machine may be the same as one of these but with a different brand name. Alter the search on youtube for many other sewing machine help videos. Good Luck. sewing machine threading highland YouTube
Aug 04, 2014 | Sewing Machines
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
I brought a new "Singer
Why not just return it and get another one? Most reviews are bad on this product, and say do not buy it, too much trouble.
Oct 31, 2010 | Singer Stitch Sew Quick Sewing Machine
Oil a 7442 sewing machine
Hi. Your manual will tell you where to oil your machine, or if it's self-oiling (in which case you don't oil it). If you've lost your manual, check with http://www.mastersewusa.com/menu-singer_iinstructional.htm; they have your manual. I wrote a small tip on oiling your machine, too.
Be sure to use good sewing machine oil in your machine. You can get it at any fabric store or order it online. One of my favorite online stores for sewing supplies is Nancy's Notions (http://www.nancysnotions.com/).
Whether or not your machine is self-oiling, be sure to keep the lint cleaned out of the bobbin area. You can use a small brush (even a little paint brush works nicely) and just brush all the bits of lint out. A good habit to get into is to brush all the lint out when you go to put your machine away after each use.
Since you're new to sewing, here's a couple more things that are good to know:
Use good quality thread. Protect your thread supplies from dust and sunlight. Old or cheap thread breaks easily and gives off more lint.
Use a new needle with each project you sew and make sure you use the right size needle and thread for what you're sewing. I wrote a quick guide about which needle to use with what fabric.
Most problems you experience with your machine can be solved by rethreading your machine or changing the needle.
Happy Sewing!
Robbie
Apr 15, 2010 | Singer 7442 Mechanical Sewing Machine
When i sew the machine squeeks - what could this be
Probably needs a bit of oil. Someone once told me they use a bit of olive oil in the workings and try sewing on an old bit of calico/cloth. Hope this helps
Sep 15, 2009 | Sewing Machines
Necchi sewing machine
i repair a lot of sewing machines as a hobby .. the necchi is one of the better ones .. they are easy to use and work well .. i almost always dontate the repaired machines to places like "womens shelter" .. "home for troubled girls" or just give them to someone that has nothing or cant afford new machines ... it sometimes makes a difference in their life if someone helps them get started .. modern machines vary from really cheap junkers that somehow work to really expensive machines that do everything but are completely out of reach for many.. the old necchis are better than many new machines but no one knows that .. so typically they sell for only $20 to $50 ... but if you donate a working machine to someone it can help, then its worth it weight in gold ..
Jul 24, 2009 | Necchi Sewing Machines
Euro pro model 385W sewing machine
Hi FixYa,
I copied this question from off of this site for I wanted to make certain that
whoever answers my question will understand that all of the question
doesn't pertain to my problem.
"when we have it threaded the top thread keeps getting jammed up in the bottom bobbin. if i redo the bobbin as shown in manual then the bottom thread will not loop so it will stitch"
This is the only part that pertains to my problem...... when I have it threaded the top thread keeps getting jammed up in the bottom bobbin......and I can't get it to sew at all....it won't do nothing.....the motor will just sit there and grind.
Thanks,
Kay Nowicki
Aug 27, 2008 | Sewing Machines
It will not sew
SEWING MACHINES ARE TRICKY...JUST ONE LITTLE THING AND THEY DON'T WORK. SINCE YOU SAY IT JUST WON'T SEW LETS START AT THE BEGINNING. FIRST, I WILL ASSUME THAT THE BOBBINS YOU ARE USING AND THE NEEDLES CAME WITH THE MACHINE WHEN IT WAS NEW. O.K. NOW, TENSION MAKES YOUR MACHINE SO IT CAN SEW. YOU HAVE TO WIND YOUR BOBBINS WITH THE CORRECT TENSION, OR YOU WILL A BEAUTIFUL STITCH ON TOP AND YOUR MACHINE WILL STOP DEAD WITH A MESS ON THE BOTTOM OF YOUR CLOTH. YOUR MACHINE MAY OR MAY NOT HAVE A TENSION SPRING THAT NEEDS TO BE SET WHEN YOU THREAD YOUR MACHINE, BUT MOST NEW MACHINES DO NOT HAVE IT. WHEN YOU PUT YOUR BOBBIN INTO THE HOLDER, MAKE SURE YOU ARE PUTTING IT IN THE CORRECT WAY--IT WON'T WORK IF IT IS IN BACKWARDS. NEEDLES, THE WRONG NEEDLE CAN CAUSE YOUR MACHINE NOT TO WORK. A NEEDLE THAT IS SLIGHTLY BENT WILL NOT WORK. ON YOUR BOBBIN HOLDER, THERE IS A SCREW, MAYBE SOMEONE MISADJUSTED IT. THIS WILL MAKE YOUR MACHINE NOT WORK. IF YOU HAVE DINGS IN YOUR PLATE, IT WILL CUT YOUR THREAD AS YOU SEW, YOU NEED TO USE A PIECE OF CROCUS CLOTH TO FILE THEM DOWN. THESE HAPPEN WHEN A NEEDLE GETS BENT AND HITS THE PLATE INSTEAD OF GOING DOWN TO GRAB THE THREAD FROM THE BOBBIN. MAYBE SOMEONE IN A LOCAL SEWING SHOP, OR QUILT SHOP CAN HELP YOU BETTER, AS MACHINE PROBLEMS ARE HARD TO DIAGNOSE WITHOUT HAVING THE MACHINE TO NOODLE WITH IN FRONT OF YOU. MAYBE ONE OF MY IDEAS WILL HELP...I HOPE SO.
May 26, 2008 | Yamata FY700 Mechanical Sewing Machine
Designer 1: upper thread shredding while embroidering
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Apr 17, 2008 | Husqvarna Designer I
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Are you a Sewing Machine Expert? Answer questions, earn points and help others
