Ricoh Aficio 551 display reads "functional problem" and to turn the power off
  • pbnow Sep 23, 2008
    Ok, the printer finally failed again, The display reads:
    Functional Problems
    Turn Main Power Switch off then on. If the error appears again, call service.
    SC2002FFD17900
    Call Tel 00-0000-0000
    What do you think?
  • alfakomerc May 21, 2009
    I have the same proble and in SM it is point like printer controler board defective.I think also must be solution with software.If some one know how to fix it please let me know.Thanks
Thank you very much for trying Inky.
I appreciate your efforts. I couldn't find anything on this problem either. I guess it's time for a new one, because the service guy we had couldn't fix the problem and it cost an arm and a leg for him to do nothing.
Sincerely,
Bob
Posted on Sep 24, 2008
  • 691 Answers
Does the machine give an SC code number i.e. SC541
Posted on Sep 16, 2008
  • Inky Fingers
    Inky Fingers Sep 23, 2008
    I can not find any info regarding that SC code. Most machines give a 3 number code like SC 541, SC 121 etc. These codes point to a particular component for the engineer to check. Unfortunately I can not help further with this error as I can not translate the error code.
  • Inky Fingers
    Additional info:
    If your machine has a type 700 print controller, the error message will most likely point to a software problem in the controller. Try passing the controller and connect directly to the 551, disconnecting all the controller connections. If the error clears, you know the controller is faulty. It is usually possible to install the controller software and rectify most software errors.
Error display hc551 for Ricoh Aficio MP1600le, pl help me how it solve the problem.
Error code: 551 - Fusing thermistor open (rear)
The fusing temperature detected by the thermistor is below 71C and is not corrected after the main power switch is turned on.
Causes:
- Fusing thermistor defective or out of position
- Power supply board defective
- Loose connectors
Apr 29, 2015 | Ricoh Office Equipment & Supplies
Service SC 990 RICOH Aficio 551
sc990 is a general software error. It could be caused by a specific application or function, or it could be caused by a problem with the process control. In general, you can get rid of the sc990 error by turning the machine off with the main power switch (the orange switch on the left side of the copier) but if the error comes right back, the best first solution is to update the machine's firmware.
Nov 18, 2010 | Ricoh Aficio MP 1600 Black and White...
Ricoh Aficio 551 w/ sc366
sc 366 is hard disk drive bad sector will need to call in a engineer to fix this problem might need a new hard disk if he cant format it make sure you always shut the machine down correctly switching it off in correctly causes this fault to occur
Jul 14, 2009 | Ricoh Office Equipment & Supplies
Aficio 551 - error code SC124
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Mar 03, 2009 | Ricoh Aficio 450 Copier
Ricoh sc 551
This is a fuser temp. problem -- must reset and/ or replace thermistors.
Press clear modes button then 1-0-7 then hold down the clear stop button.
When display changes touch copy sp modes.
Turn may power off and wait about 30 sec.
Turn power on.
If the machine comes to ready you are ok for now.
If code returns you must replace thermistors.
If you need to replace thermistors, contact me and I will get you part numbers and instructions.
Jan 15, 2009 | Office Equipment & Supplies
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
387 people viewed this question
k24674
jasbo
jasbo
