Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Green blinking light and no TV picture.
The blinking can last an hour or a weekend. Its happining more frequently now and im unable to get it to reset. When its working its perfect but i cant afford the repair call cost. Ive been quoted 160.00 just to drive the 4 miles to my home and another said it needs a computer at 700.00 dollars minimum. Ill buy a new LCD for that price. Is there a fix for this problem that i can do. Im a pretty good fix it person and i can follow directions. Thankyou Tim
  • tomlan515 Sep 20, 2008
    Yes, My WS65813 has the same problem too. It is 4 year old. No insured. I can't afford $650 fixing cost. Please let me know if you have a good idea. My email:
  • sunzhu721 Sep 28, 2008
    I had this problem before when it was under warranty and the guy came and fixed it and said i had mashed a button (********) but it still does it. it Saturday and i can't watch college football so if you find out how to fix it help me out.
  • 3 Answers
SOURCE: mitsubishi hd 1080
Tech Man is right on with his suggested solution. Just wanted to add that your TV may contain a series of pico fuses that will have a bluish of greenish color (sorry...I am a little color blind). They will have a similar shape to a 1/4 watt resistor without the color bands and will have location IDs such as FA005 or FD005 etc. You should also be able to get the values of each of the pico fuses from the circuit board around the location Ids as well. But as mentioned by Tech man, make sure you do not have a defective diode or transistor first or you will not only open the possibility of "back to square one" but things could get worse. Hope this info. helps.
Posted on Aug 20, 2006
  • 1694 Answers
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address..... .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Posted on Jan 07, 2008
A quick fix for this is to use a hair dryer to heat up the capacitors and then plug the tv back in.  It should only take about 90-120 seconds to heat them up depending on how hot the dryer is.  The cap's are located on the right side.  Take the front cover off the TV, and heat up the box that is about the size of a small cable box on the right side.  Once the cap's are warm, they will stay warm as long as the TV stays plugged in.
Scott out
Posted on Jan 31, 2008
SOURCE: flashing green button, won't reset or turn on
i held menu and device for about 10-15 seconds on my WS-55515 and the blinking went away and my tv works just fine after that
Posted on Apr 21, 2008
SOURCE: blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Posted on Jul 02, 2008
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
May 24, 2012 | Sony KDF-50E2000 50" HDTV
HCL4715W Green Color intermittently projecting
It sounds like the common problem with this set. It is an intermittant picture tube, or there is a loose connection on the green drive board on the green picture tube. Try lightly tapping all around on the green drive board while the set is on and see if you have any change. BUT BE VERY CAREFUL! Lots of high voltage on the board. Also use a plastic or wooden device to do the tapping. If you do great, you know you need to resolder the connections on the board or clean the CRT socket on the green drive board. If there is no change, I would bet the green CRT is on its way out. But try tapping the green drive board all over as I said before, that is a very very common fault with these types of TV sets. Good Luck
Aug 16, 2007 | Samsung HCL4715W 47" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services ( and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
5 Blinks, no picture
Power supply (start up) failure.
Mar 04, 2008 | Sony KP-51WS500 51" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Green color comes on and off
I need some answers here... Do you have only one video source to test it? Is this happening with an external source or with your tv tuner or both? I need more info....
Aug 10, 2007 | Samsung HCL4715W 47" Rear Projection...
JVC PD-42WV74 tv turned itself off and unable to turn it back on. Green light blinks on receiver and TV.
Unplug the TV set, after a few minutes, plug it back again. If you are lucky, the TV will be okay!
May 07, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
