Question about Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator
Programming Phone I brought phone -- cannot programm it. Can't get the month to come up or LCD screen to appear? Thanks, Jean
  • elocklin Sep 26, 2008
    Basically, it works fine except I cannot figure out how to change the dialing preference from pulse to tone dial.
It's not quite that easy but Jeancart did lead me to the solution. Once you press "set" under the dialing pad, the "up" and "down" keys on the right bank of the facia of the phone will scroll you through a menu. I never did see the dialing mode but when I replaced the batteries and plugged the phone line in, it worked. So, I guess I did something right. Hooray!
Ed Locklin at mp367.
Posted on Sep 30, 2008
I BROUGHT THIS PHONE TODAY AFTER PLAYING WITH FOR A WHILE I TOOK THE BATTERIES OUT AND LET IT SIT BATTERIES MUST BE NEW BEFORE YOU PLUG IT IN THE 2005 OR 2006 SHOULD BE ON THE SCREEN PRESS SET AND YOU SHOULD SEE THE FIRST SCREEN THEN JUST PRESS THE UP AND DOWN THE SET EVERYTHING AFTER THAT. SHOULD BE PROGRAMMED BEFORE PLUGING IT INTO THE PHONE LINE.
Posted on Sep 29, 2008
Factory reset please help me to reset my Mitel
Reboot phone and hold down the down arrow key. This will put you in the programming of the phone. Use * and # to toggle thru until you see default . Then follow screen to save and reboot
Sep 18, 2013 | Mitel 5215 IP Phone
Tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 | Lands Phones
I have the message CO Not assigned ,How can assig CO? panasonic kx-t7730
Press program button, select button you want to program, dial 0 then dial CO number as in 001 according to which CO line you wish to program. If you are not sure which CO line is missing, check the button programming by the same method. Press program button then any programmable button and it will be identified in the LCD screen. The CO lines may be 2 digit if you have an older system as in 01, 02, etc
Jan 26, 2011 | Panasonic KX-T7730 Corded Phone
I can't changed name on my phone. please help me.
The extension names can be changed in admin programming from a predesignated programming phone. Typically this phone is the attendant phone as in ext 100 or ext 101.This phone needs to have an LCD screen.
1) Press <program>
2) Dial **1234(1234 is the default admin password)
3) Dial 004 for Ext name programming
4) Press <enter>
5) Dial extension number that you want to change name of as in 102
6) Enter name (20 characters or less )
7) Press <enter> to store
8) Press <end> or lift handset and return to cradle to end programming session
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
I have a few issues right now with my LCD 12B. 1. I have been trying to program one of my programmable buttons to be able to speed dial an outside number with just one touch of the button. I am having...
Hi, rather than try to send you written instructions you need to watch this video, then go to http://www.abbeytelecom.com and search 'programming the soft-keys ( they need to be an SPD)' then search 'how to add members to a group' and add the extension back into the operator group. hope this helps!
Aug 04, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
Is there a CPS on the I9 ?
I just spoke to my supplier !!
He knows his stuff.
Thanks for your support,
Jean
Jan 28, 2009 | Dual Electronics CECT P168 Cellular Phone
Backlight or lcd problem
Hi. It sounds like the backlight of the LCD has failed. If you replace the LCD screen that'll solve the problem. See http://www.formymobile.co.uk/proddetail.php?prod=w850lcd
Nov 14, 2008 | Sony Ericsson W850i Cellular Phone
Nokia 6265
The screens are easy to replace on this phone, the screens run about $35-$60USD on ebay. i would see what the cost of repair and shipping versus buying the part and fixing it yourself.
Mar 10, 2008 | Cell Phones
LCD Display
hii
i had the same prob. and the solutions of it is ( just press the * ) and thhings will be back to normal .. i hope :)
take care
Jan 29, 2008 | Panasonic KX-T7730 Corded Phone
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Oct 30, 2006 | Samsung Prostar 816 Phone
Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator Logo
41 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
k24674
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
