Question about Dell Dimension 5100 (D51L1) PC Desktop
No video Hi:  I start on computer the green light is already but no video.
  • Jeff Strader
    Jeff Strader May 11, 2010
    which green light? are the fans in the computer coming on? please describe the problem a little better if at all possible.
    Scholar:
  • 55 Answers
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Posted on Nov 25, 2008
Green light flashing but computer is dead. what to do?
The green light on the motherboard? Your Computer has a few miles on it. It may be the PSU needs replacing. Also replace the CMOS battery and reseat/replace the Memory Mods, if you haven't already. If you unplug and plug in does the computer try to start? Fans spin? LED's blink? Anything? If it starts and shuts down in a few seconds that would, most likely, be a Power Supply issue. Their is a chance, of course, that it's just done.
Mar 19, 2013 | HP Compaq Presario SR2150NX PC Desktop
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Hello I have a samsung sync master 732n monitor. The power button just blinks but the monitor doesn't turn on it's properly plugged in to my computer. This has happened quit a few times already. When...
Hi your monitor is working ok but your pc display is the problem.
1.-take out the Memory and clean with eraser the gold part of the memory and your problem will be finish .
if still same means maybe your video card or board .
if your board have a video card build in take your video card and use only built in video
last press the keyboard Num Lock and look if ther is a light green
Nov 03, 2010 | Samsung Computers & Internet
My monitor won't come on, the green light blinks, but nothing shows up on the screen at all. i've already changed the video card but that did not fix it. prior to changing the video card, once in a while...
try shining a light directly on the screen to see if youve got a backlight failure, if you have there will be an image on the screen but nothing lighting it from behind thus making it seem blank, if that is not the case id start with the vga cable and work from there
Sep 26, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Computer fans spin, green light but no video or sound
All you can do is open the case and reseat every component you can, especially the video card and memory. If that does not work the only way to narrow down the source of the problem (using the information you provided) is start replacing parts with known good parts.
Jul 10, 2009 | Compaq NX6110 TFT XGA Notebook
My lcd monitor lights in green but does not display
That is definitely not normal. Try a different monitor on the computer and if you get video on the new monitor then you know your original monitor is bad for sure.
Sounds to me like its a problem with the lcd or the inverter. You might want to try and take apart the monitor and reseat both ends of the LCD cable. If that doesn't help then the monitor is faulty and you'll have to get another one.
May 12, 2009 | BenQ FP71G 17" LCD Monitor
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Dell Dimension 5100 (D51L1) PC Desktop Logo
195 people viewed this question
Alun Cox
