Question about HP DeskJet 6540 InkJet Printer
Printer leaves black spots on paper
When printing, my printer suddenly started printing black rectagnle shapes on the left side of the paper. I can print anything important because of this.
The black spots mean you either need a new imaging drum, transfer kit or fuser. You'll have to print some stuff and try to catch where the black marks are appearing. Try this method (it's called a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The MOMENT the tail end of the paper disappears into the printer, open the right door. Open the front doors and release the levers for the imaging drum and the transfer drum. Carefully remove both pieces and examine your paper.
You should find the paper partway on the transfer belt but not in the fuser. If you see black marks here, start with the imaging drum. Open the shutter that covers the sea green shiny roller and look for marks on the drum (you'll see build up on the edges, that's normal, you should not see any scratches, pockmarks or toner on the center of the drum). If it looks clear, take a look at the transfer drum for marks or cuts on it's surface. (note: the transfer drum can be cleaned off with a dry lint free cloth, do not touch the shiny sea green roller of the image drum)
If everything looks good there, then likely the black marks are coming from the fuser. Let the printer sit, turned off for about half an hour to allow the fuser to cool. You can then remove the fuser and look at the rollers to see if there is any build up or damage there.
If you are not seeing any obvious issues with any of these parts, then start with the imaging drum. If you know that any of these parts have never been changed, then change them as they do have a limit to how many pages and how much time they can be used for.
Posted on Feb 17, 2009
Black line on left side of paper
I forget the terminology but I believe there's either dirt or a sheet of paper on an internal roller.
You might try here for HP help.
Aug 12, 2012 | HP LaserJet 1300 Printer
DELL 3100 CN LEAVES DOTS ON LEFT SIDE OF PAPER. when the paper is printed there are black dots even spaced on the left hand side of the paper
replace the drum unit, if the problem persists check the Leser unit (unit scan), open it and clean the mirrors and lenses gently with alcohol and toilet paper
Oct 27, 2011 | Dell 3100cn Laser Printer
Our printer is leaving black spots on everything it prints and no matter what I do (change cartridge/clean out) they get worse and worse. What do I do?
hello, you might want to do a half test, i will explain, when the printer starts printing, open the front cover after paper has started to pick up and has gone halfway into machine, pull toner cartridge out, and check print, if the black spots are there, then the problem is toner, if not then it would be fuser.
Sep 30, 2010 | Lexmark Optra T610 Laser Printer
My HP Photosmart suddenly started blobbing out ink.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Photosmart D7260 Printer
Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
Apr 23, 2008 | HP LaserJet 1020 Printer
Black spots of the left side of the print
If you know how to remove your drum cartridge, take it out and check if you don't see your black spot on your drum....If so, replace your drum cartridge.
You may have a bad fuser to....
let me know !
Apr 01, 2008 | Samsung Laser Multifunction Printer Toner...
Print Heads snagging paper
well if u have a straight paper - it´s the printers fault
ask for a replacement from the place of purchase or from the manufacturer
Dec 24, 2007 | Epson Stylus 1400 InkJet Photo Printer
Colors faded on left side of paper black and blue
Is it possible for you to clean the printheads manually with cotton buds and cleaning solution on this unit. Clean all thoroughly and this might just correct issue.
Sep 01, 2007 | HP Color LaserJet 3500 Printer
HP DeskJet 6540 InkJet Printer Logo
1,895 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
