Question about GE Kitchen Ranges
Ge model jbp45g clock and timer stopped working cannot reset.
    Problem Solver:
I just solved it by accident. I kept punching all of the buttons on the panel and all of a sudden the clock came back. It is a mystery but it is working okay.
Posted on Sep 17, 2008
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
My ge model 15117 heavy duty timer will not go off in the auto mode. I changed it from auto to off to turn my pump on and then went back to auto and now did not turn off when timer expired
I cannot repair defective timers, and there are complaints about this timer's MODE button.
Most people complain they can't get mode to set.
Avoid the MODE button after programming timer.
Reset the timer by pushing CLOCK PROG MODE buttons. Then re-program the timer per instructions, and then press CLOCK button to exit programming and timer is in Auto mode and ready to work.
No need to press MODE after programming timer.
Typically, this timer has limited 1 year warranty.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15117
15117 is not heavy duty timer. Both outlets combined are rated 1000 watts incandescent and 1/4 HP. Check nameplate on your pump for HP rating.
For limited-lifetime-warranty timer, rated 1/3 HP, choose Intermatic HB800RCL 2-outlet timer.
Cost twice as much as GE 15117.
For 1HP outdoor pumps choose Intermatic P1121
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 08, 2011 | Sport & Outdoor - Others
How do I reset the Polder Clock Timer - the narrow white one which has clock, count up and timer?
Timer is not identified for certain
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical manual says to hold down clock button for 3 seconds until display disappears.
Another part of manual says to press start/stop then clear to reset timer to 0:00:00
Another part of manual says to press clear to reset timer back to 00:00:00
http://polder.com.p2.hostingprod.com/images/instructions/898_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 27, 2011 | Polder Triple Digital Timer Model 891-90
I noticed the Tork 1104 timer box was not working. It does not make a sound. And the clock does not move. I measured the incoming and outgoing wires with a multimeter and both measure at 240V. I'm...
13 years is good run for clock motor. Timer will last longer than clock motor.
Open following link to identify timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Tork 1104 has 240Volt clock motor
Frontier lighting sells the >> 120V Tork motor: List price 40.33/ your price 45.49
So 120Volt replacement motor costs as much as new replacement timer
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Intermatic replacement is240 volt T104 timer for $49.62 with 'free' shipping:
Also Intermatic trippers and clock motors are cheap and easily available
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88
Crossover wiring from 1104 to T104.
Tork L goes to Intermatic 1
Tork 1 goes to Intermatic 3
Tork x goes to Intermatic 2
Tork 2 goes to Intermatic 4
Intermatic A is not used unless you have neutral wire or 277V
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
GE sells the same 240Volt Tork timer under GE model 15307 in indoor-outdoor enclosure available at Home Depot for $59.00. Year 2011, GE does not pay US income tax, but takes US profits and pays tax in foreign nations. No replacement clock motor is available, but crossover wiring is same.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Upvote the help.
May 09, 2011 | TORK Variable Cycling Timer 8601
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
Brand new Woods Timer (Model 59730) turns on/off correctly, but completely stops during "off" hours every day. When I reset the current time, it runs for about 8-10 hours, then stops. Returned...
It seems odd that you'd get two defective timers.
I bought one of these timers from Home Depot under the GE brand and the dial rotates correctly as time passes.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
Woods 59730/ GE 15107 timer is a mechanical timer, so circuit problems should not affect clock motor.
On electronic timers, if circuit is not clean (circuit has ground fault), then timers don't last long and do peculiar things.
My suggestion is to try timer on indoor plug, on a different circuit breaker, for 1 day and see if it keeps running.
This will tell you if outdoor plug might have a loose wire, and that electricity is getting cut off.
Add a comment and tell me what you discover, or add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 22, 2011 | Hardware & Accessories
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
TIMER SEEMS TO STOP WASHES AND SPIN ONLY IF YOU STOP AND MOVE KNOB, At GE parts does the same timer work on all GE washers for about a little over &100.00 online
Try to buy the one for your model. That seems like a high price when all you probably need is the clock motor capsule itself. With the back of the control panel off, place a small screwdriver near the clock motor winding--if it has power and the winding is intact, the screwdriver will vibrate. If it does, the motor capsule is stalled. I've poked a hole in the plate where the small gear is and squirted WD-40 into the interior which sometimes gets it to work. I've never been able to find just the clock motor capsule as a replacement. Business Idea?
Oct 20, 2009 | Washing Machines
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
116 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
