Question about Sony Handycam DCR-SR100 Camcorder
My new Sony DCR-SR68E shows hard disk format error and E:31:00 error every-time I star it. It doesn`t shoot anything. It doesn`t even get formated. Please let me know if there is anyway to solve this problem.
    New Friend:
SonyDCR-SR68E HDD Format error
Go to Menu-Show Others-Media format-HDD-Yes-Yes-ok
you must be solve your problem.
Never format your camcorder with NTFS or FAT system format using your operating system Windows.
Posted on Oct 21, 2013
SOURCE:
SOURCE: sony handycam DCR SR65 HDD format error E31:00
Recently purchased a camcorder DCR-SR68 and we took all our wedding video on it. It now says HDD format error and all my video is gone. I tried resetting didn't work, took out the battery, didn't work. Sony told me to format the drive but that also not function. couldn;t format that.
Is it possible to recover this video??? can i solve that problem?
please send to solve that problem
Posted on Dec 18, 2010
  • 3 Answers
SOURCE: E:31:00 error it says format
Recently, I faced the same problem with a Sony XR-155 camcorder while being on vacation. Fortunately, I managed to recover my videos. First, make sure that you as little as possible to the hard drive in the camera menu, so I would not recommend to rebuild the image database or to reformat the drive.
Connect the camera to your PC in the same way that you would usually do. When I tried to access the drive in Windows Explorer, I got a message that the drive was not readable and needs formatting. You do NOT want to do that. I decided to make a full backup of the drive first, so that I could safely fiddle around later on.
The program that I used is Paragon Drive Backup. It gave me a few error messages during the back-up, which I all ignored, and after about 1.5 hours the copy was ready. The next step was to mount the image as to a free drive letter. I figured that I would need some kind of data recovery tool to extract the data, but to my surprise, the mounted disk image was readable in Windows Explorer as if no problem had ever occurred. Luckily, I was able to extract all of my videos from the camera in this way.
Of course I do not know for certain whether this technique also works in your case. For instance, it could be the case that the code E:31:00 is a generic HDD error message and therefore, it might be the case that your camera has a different problem than mine had. However, I think it is worth the shot to try to recover your data in this way (I assume Backup & Recovery 10 Suite does the same trick, a demo version is available on http://www.paragon-software.com/downloads/home/).
This procedure of course does not fix your camera (what I understand from various massages across the internet is that you should send it to Sony to get it repaired), but at least you might be able restore your data. I hope that you will be successful, good luck!
Posted on Sep 24, 2010
SOURCE: HDD format error (E:31:00). I
I get Error.No. 31.00 HDD format error on my Sony ECR SR32
Posted on Nov 26, 2010
SOURCE: HDD FORMAT ERROR FOR SONY HANDYCAM DCR-SR47, when
follow this instructions
1-home menu
2-manager media
3-media format
4-hdd and putYES
CONGRATULATION!!!!
Posted on Sep 22, 2010
  • 3 Answers
SOURCE: E:31:00 Error Code on sony camcorder
Sony DCR-SR68E was showing error:31:00 and i went on and unplugged the hard drive and then plugged it back in. now its showing error C:13:02 saying overheated cannot access media. help me please
hi,
your HDD is either not connected properly or the connector is gone opposite side, please check it and correct, if the error code is showing again go to menu, manage media, then format disk
Feb 12, 2016 | Sony DCR Video Cameras
HDD format error
Format the hard drive, if you still get that message the drive is broken and needs to be replaced by a professional.
Jun 11, 2012 | Sony DCR-SR68E/S Handycam(R) PAL Video...
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
I am using sonu handicam dcr-sr68..and it is showing formet error..and is not doing any work...pls help me
Possible there are errrors in the memory. transfer the recorded files and then format the drive. If not connect to the PC after downloading the software and check for errors. If not there are errors in the drive.
Oct 27, 2011 | Sony DCR-SR68E Flash Media, Hard Drive...
When I format my sony DCR-SR68E then it show "unable to format" and its show a time "E 30:00" and when show in my lcd panel HDD format error. Please help me.
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem
how are you trying to format this usb hard drive it might be listed as a mass storage device
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 21, 2011 | Sony DCR-SR68E/S Handycam(R) PAL Video...
I have a Sony handycam DCR-SR47 I turn my camara on and it doesn't work. it says format error 52
Camera Hard Drive got some error and needs to be formatted through camera menu format option.
All data on Hard Disk will be deleted by formatting it.
Oct 23, 2009 | Sony DCR-SR47 Camcorder
Sony Handycam DCR-SR100 Camcorder Logo
953 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
