Question about Vulcan EF3 Deep Fryer
HOW TO DRAIN THE OIL?
IS THERE A PETCOCK LALVE TO DRAIN THE OIL FROM THE OLD FRYER- ANS Z21.27 WE HAVE AT OUR VFW POST? WHAT OUR THE ALTERNATIVES TO EMPTY THE FRYER OF COOKING OIL?
HENRY
  • 21 Answers
It should be in the front of the fryer after opening the front door there is a 3/4 drain valve
Posted on Nov 19, 2008
Cant drain oil from fryer
Is it a commercial type fryer with a drain in the bottom? We used to keep a straightened out wire coat hanger behind the fryer to poke through the drain. Open the tap and poke the wire through to start the flow,
Jan 03, 2018 | Kitchen Appliances - Others
Why did it stop working?
Big Boss™ Oil-Less Fryer - BedBathandBeyond.com
www.bedbathandbeyond.com/.../big-boss-oil-less-fr...
Bed Bath & BeyondHome > Gifts by Interest > Healthy Living > Big Boss™ Oil-Less Fryer. "Big Boss™Oil-Less ... Right size for family cooking, fried taste without oil, does what it is supposed to do ! ... I purchased a new one when my old Big Boss stopped working.
Big Boss Oil-Less Fryer Reviews and Complaints - Genuine ...
www.asseenontvonsale.com/kitchen/big-boss-oil-less-fryer/
Feb 22, 2012 - The working of Big Boss Oil-Less Fryer is very simple. ..... I am returning it because it does not work (does not turn on) but I don't want another ...
BIG BOSS KITCHEN PRODUCTS - Facebook
Dec 25, 2015 | Big Boss Oil-less Fryer
What is the standard way to empty the oil from the fryer
You should have a screw on drain valve that screws into the opening under the fryer, inside the door.. Once you have the drain valve screwed on, then open the valve and it will drain into whatever you set in front of it... If you need to order a drain valve, they are not expensive... I can get you a price if you need one... Susan @ Restaurant Equipment Outlet, Cinc, OH reocincinnati@yahoo.com or call me at 888-542-5959... I will need model number also.
Aug 19, 2011 | American Range AF40 Deep Fryer
Oil comming out of air intake
The oil coming out of your carburetor is coming from your crank case. Either you have a stuck float, a stuck float needle, dirt in your carburetor, or you have a vacuum style petcock with a leaking diaphragm. Take apart and clean your carburetor. Drain your tank , take apart and inspect your fuel petcock. If the diaphragm is bad repair it with a K&L rebuild kit or put on a new petcock. Inspect your air filter if it is saturated with oil replace it and drain the excess fluid out of the air box. Also check your engine oil, if your crankcase is too full (gas/oil mixture) you will need to change your oil before running the engine.
Jul 16, 2011 | 2005 Yamaha V Star 1100 Classic
There is oil and gas coming out of the carburetor. What is the problem?
Jun 27, 2011 | Suzuki Intruder LC 250 Motorcycles
Pump sounds like it is kicking on but will not pump oil back into fryer
Drain the oil, clean the vat completely of any food residue. Let it dry out completely. Refill with oil and turn heater on.
If your screen is plugged, (in the pump housing,) It will not pump oil.
Nov 16, 2010 | Pitco Frialator SG14 Deep Fryer
How to drain oil from fryer
Most fryers have a valve right inside the front door that you can place a bottle under and drain the oil right into it...
If not then get a small diameter plastic hose from a hardware store and siphon the oil out...**** the oil up the hose till it is over the side of the fryer, then hold the vacuum and drop the hose over the side and lower then the oil level and the oil will start to siphon out...
heatman101
Sep 03, 2010 | Imperial IFS40 Deep Fryer
Emptying the deep fryer
Ther below taken straight from the RIVAL web site.
Remove the oil bowl by lifting the bowl straight up out of the plastic exterior. To replace oil bowl, be sure the brass guide post (between the 2 electric prongs on the bottom of the bowl) is aligned properly with the center hole of the receptacle in the bottom of the housing. The brass guide post should guide the electric prongs into the correct position. Firmly press on bowl to ensure it is positioned properly. Lid should close tightly.
http://www.rivalproducts.com/help.aspx?helpNav=1
Dec 26, 2008 | Rival CZF625 Deep Fryer
T-fal
me too. ... it won't drain !!!!!!!!!
Jan 09, 2008 | Tefal Ultimate EZ Clean Pro Deep Fryer
Vulcan EF3 Deep Fryer Logo
340 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
