Question about Garmin GPS
When I am connecting my GARMIN 340C GPS to the CAR 12V DC charger it Blinks.What may be the issue ?
    Scholar:
  • 147 Answers
Sounds like the GPS is trying to draw more current than the charger is able to supply.
Try charging with the GPS off for a couple hours.
Posted on Sep 16, 2008
Garmin nuvi 2455 won't charge on dc but charges on ac
ya no quiero tener la suscripcion a http://wingo.mx x favor yo no la utilizo y me kita mi saldo
Dec 31, 2013 | GPS
Will the garmin nuv GPS 750 Work witout a battery? Using the car power adapter only.
Yes.... You can actually take the battery out of the unit and run the unit on the DC car charger, however once you remove the charger, the unit will die immediately.
Jul 13, 2013 | Garmin nuvi 750 GPS Receiver
Will my Garmin Nuvi 40 work with a 24 volt supply ?
If you are using a standard Garmin car charger, you can connect the charger to a DC power source that can provide between +10VDC to +30VDC. The charger produces +5VDC to power the Nuvi. This can be verified on the charger label.
You can NOT connect any voltage higher than +5VDC directly to the Nuvi.
Apr 22, 2013 | Garmin nuvi GPS
Nuvi 760 will not accept charge from car charger. Does charge from USB. Car charger lights up indicating that 12V is OK. Fuse checks OK. When plugged into car Nuvi reports 'external source required for...
Your units powered cradle has probably died out, this is very common with the 7xx series, see if you have a friend or someone that has the 7xx cradle you could try. But it is a very common issue, if you do need a replacement one can be obtained from here http://www.gpscity.ca/garmin-nuvi-700-series-cradle-replacement.html
Hope this helps!
Mar 22, 2011 | Garmin Nuvi 770 Car GPS Receiver
My garmin nuvi 260 will not take a charge
garmin navs are famous for there chargers burning out. first check the fuse at the end of the 12v car charger by unscrewing the tip of.if its blown replace it. if its not blown then the charger has burned out there are after market chargers but only garmin chargers will work!! as garmin use a sensor to detect the correct type of charger is connected so be sure to buy a genuine garmin 12v charger
best of luck
please take the time to rate this repair.thanks
Aug 03, 2010 | GPS
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
http://www.sharc.net/gps_charger_repair.htm
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
After my Garmin accepts power from my car but it does not get past the "loading maps" stage. All I get is the Garmin logo? Please help!
You are using the incorrect power lead there are two available on to connect to your PC for updated this one can't be used the in the car even with a USB to 12V adapter.
You will need to buy the correct car version that is just 12V DC straigh intto the Garmin this one is just used for recharging in your car.
As far a I know Garmin is the only type of SatNav that has this Pequliarity with the leads.
Jan 08, 2010 | Garmin nuvi 250W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
Will a power cord for a Garmin 250w,200w,270,260,250,&200 work on a 255 Garmin GPS
Yes, They all use the same mini-USB connector, same AC wall charger and same DC car charger.
- Jim
SHARCNET-USA
Mar 12, 2009 | Garmin Nuvi 255 GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
GPS Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
