Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
Flashing yellow light
There is a flashing yellow light next to a symbol that looks like a test tube. we can't print. Can you help?
  • Anonymous Nov 06, 2008
    same problem
  • Anonymous Dec 16, 2008
    the yellow ink light is on and the imageing drum light is blinking on the same time
  • 300 Answers
Your printer requires a new image drum
Posted on Sep 16, 2008
I have been given a printer by my employer but had no operating instructions and I cannot get it to print out.A green light keeps flashing.Where can I download instructions and trouble shooting tips.
Gonna depend on the brand of the printer. Usually you can go to the manufacturer's website and do a search for the model name and the word "drivers" to find the correct drivers for that particular printer. Since it will print a test copy it sounds like the printer is fine and its just a question of communication with the printer. More information would be needed to help you. Is it connected Via USB or wireless? If its USB when you plug the printer in, your computer should discover it and take care of the rest, though that's not always the case. At the very least it should discover that you've connected something.
Based on some assumptions, if you're on a Windows based PC, and its connected via USB, right click "computer" or "my computer" under "Start" and click properties. In the window that opens you're looking for an option called "Device manager". If you click that, it'll list all of the hardware in use on your computer. Look for anything with a red x, exclamation point, or warning sign (looks like a yellow traffic sign). If you see any of those, its definitely a driver problem. Unfortunately, even if you don't see any of those it might still be a driver problem (gotta love Windows). So going forward we need more info. Are you on a Windows PC, Mac, or a Linux box? What brand and model is the printer? How are you connecting to the printer?
With that info we should be able to get you squared away.
Apr 13, 2015 | Office Equipment & Supplies
Symbols on fridge freezer- i have a flashing symbol that looks like a test tube with a rounded end on hotpoint fridge freezer- what does it mean?
Is the water draining from the unit? It sounds to me like that symbol is telling you the water that has accumulated from removing the moisture in the conditioned air is full and needs to be drained.
Aug 03, 2011 | Danby Portable Air Conditioner
I just replaced both ink cartridges in my esp3 printer. But when I print, the page comes out blank
You need a new Print Head:
Clean the printhead, then print a test page.
  1. On the control panel, press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes. The On/Off light continues to flash during the cleaning procedure.
  2. When the On/Off light glows steady, press and hold Quantity + Cancel simultaneously until the On/Off light flashes, then wait for the test page to print.
  3. Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
    • Is the test page blank?
  4. 1-800-421-6699,Call Kodak to Report Code BP03
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 23, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
No yellow color no test printing
take the cartridge out and look at the area that the sensor checks, and see if you see a lot of ink. it will be clear tube and you should see the ink, if it looks full, then your nozzles that go to the printhead either have air in it or the printhead is clogged up.
try doing up to 5 cleanings, and do a test print, check the nozzle test print everytime, if you do not see an improvement, then most likely the printhead will need to get replaced.
thanks adi
Dec 13, 2009 | Brother DCP 165C Compact Color Inkjet...
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Flashing Lights
From the User Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
If you don't have a User Guide click on the link below and save it for future reference.
2550n User Guide
If this solution has been helpful, please rate it. Thanks!
Jul 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Hp 1320 wont print
i think you might consider checking the toner on your printer, i.e. replace the cartridge...
hope this helps
Apr 09, 2008 | HP LaserJet 1320 Printer
Colors not print well
This could be because of a defective valve.
DO NOT CLEAN THE PIEZO PH WITH ANY SOLUTION EXCEPT ORINIGNAL BROTHER INK!!!! OTHERWISE YOU WILL DEFENETLY DESTROY THE PH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try this:
Place new carts into machine and make sure thy are secured.
Press menu then start bk copy then fourtimes arrow up. machine will be in maintenance mode and lights will flash. press 7 then 6 then 4 then start bk copy. machine will refresh ink within tubes and ph and do some cleaning. when done press 7 then 6 then 3 then start bk copy. machine will do a power purge.
Leave maintenance afterwards by pressing 9 then 9. Do run a test print by pressing ink etc.
If you still cant see any yellow and/or magenta the ph is defective and needs replacement.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
260 people viewed this question
Seeker5211
Seeker5211
