Question about Ricoh Aficio 1035 Copier
1035 firmware Check on copytechnet.com and see if a tech on there can get you the firmware you need. If that doesn't work, leave me your e-mail address and I can get you a set.
  • Tim Babcock
    Tim Babcock Oct 03, 2008
    I just ran into a customer with a similar problem with the stamps. I heard something about copying it onto nvram. Did that do the trick?
  • Tim Babcock
    Tim Babcock Nov 03, 2008
    Clean you feed tires off with some cleaner and see if there is any traction left to them.  If the wheels feel real smooth it wouldn't hurt to get them replaced.
    Problem Solver:
  • 7 Answers
Many thanks for your replay
ma7moud_fayed@yahoo.com
Posted on Sep 17, 2008
  • ma7moud fayed Nov 03, 2008
    hello BUBBA
    i have big proplem in my douplex richo aficio 1085 always misfed in 5 th paper what is the wrong
  • ma7moud fayed Nov 04, 2008
    thx bubba it was tha douplex fuser
I need a keyosara task alfa 180 services ook
I think the Kyocera copier service manual you are looking for is available for download at http://www.copytechnet.com
Apr 19, 2014 | Kyocera Office Equipment & Supplies
Ricoh 1035 error sc 818
hi
this error happened when :
Incorrect Function DIMM installed in Slot #2 on Controller PCB. (Slot #2 is for PostScript Option only) so you can:
Reload System Firmware.
Replace Controller PCB
for fix that.
Oct 25, 2012 | Ricoh Aficio 1035 Copier
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
ERROR CODE sc865-01, TRIED CALLING TECH SUPPORT BUT HOLD TIME WAS FOREVER & CLOSEST TECH IS 4HRS AWAY WE HAVE ONLY ONE MULTIPURPOST SO WE ARE COMPLETLELY DOWN
Your message is not clear because you have not told us what type of machine you are having problems with.
As far as I can tell it is a Ricoh copier. First of all I would suggest turning off the machine, leaving it for 5 minutes and then restarting it. Sometimes it is just a sensor which is throwing a fit! Next I would check the toner level and the waste toner bottle. Finally check that the paper pathways are clear.
These are just commonsense suggestions and I apologise if you have already tried these.
Further research on the internet shows that it may be a hard drive error, if you can locate the hard drive -with the power off - check all the connections. If you still have no luck then you may need to format the drives
http://www.copytechnet.com/forums/ricoh-savin-gestetner/12877-ricoh-aficio-mp-c4500-error.html
Hope this helps
Feb 28, 2011 | Office Equipment & Supplies
Axis 9 - Doesn´t work properly. It´s crazy !!!!!
your set needs to clean and service have a tech do the work on your set.good luck
Apr 01, 2009 | Nu Mark AXIS 9
Hello MR dricha
The firmware is only available on Ricoh service website. You have to be an authorized service technician to get in. It also require a special flash memory card that is pcmcia based as well as a $300 software program to put it in for a company in Germany. It's better to find a technician in your area to do it. You may find another solution around by checking out copytechnet.com. It's a free website for copy technicians. There maybe a Ricoh technician who can assist you on there.
Sep 12, 2008 | Ricoh Aficio 1035 Copier
A lot of problem WRT54GR with DHCP, gmail, hotmail, google earth, deezer.com ...
Try settings up the MTU to manual.
1500/1400/1300 for cable connection.
1492 for DSL. if this may not work then yes, you need to upgrade the firmware.
Aug 21, 2008 | Linksys Wireless-G WRT54GR Router
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
198 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
