Question about Cameras
I have a problem with my Olympus C-750UZ. I stripped it down and replaced the bios capacitor and display screen. The top cover of the SD card assy came off and a small black spring (approx.16mm long x 1mm O/D fell out. I cannot see where this spring is located. It must have something to do with retaining and releasing the SD card. Can you help? Thanks Bill Erratt
  • barblessbill Sep 16, 2008
    I have the spring but I cannot work out where it should go. I need some one with Olympus Camedia C7***UZ series camera repair/refurbishment experience to help.
  • barblessbill Sep 17, 2008
    I have now found out from my local camera repair shop that the spring is mounted on a pin which also carries a small latch. This assembly then locates in a groove in the terminal block, and is held in place by the terminal block cover. I was also told that this assembly often shoots out of the groove when the cover is removed, so I carried out a search of my working area and found the pin and latch.
    My Camera is now back in full working order.
  • 928 Answers
The spring goes on the SD card door. When you look at the SD card door you can see a notch on it where the sping is attached to or locks itself on to. When you put in the door, you have to put in the spring first before attaching the door.
Posted on Sep 16, 2008
  • 763 Answers
Sir if you know how to fix your device then the only thing to do is to buy that missing spring. i dont know if that spring is available on some electronic shop but if you cant find one then let the technician help you for they have tools and spare parts. hope that helps sir!
Olympus write protect
What model Olympus camera?
If it uses SD cards, SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 15, 2013 | Cameras
Many cameras will only display pictures taken by that camera (or at least the same model). Also, if a picture has been edited in any way (opening a pic in a photo editor and saving it without making any changes counts as editing) then the camera will not display it.
Feb 21, 2012 | Olympus Stylus Stylus Tough 8010 / mju...
Machine will not boot up shuts down after 5 secs
My question is have you checked the Electrolytic Capacitors on the motherboard? THOROUGHLY checked them.
(Motherboard out in hand, good lighting, and perhaps a magnifying glass)
If the Power Supply voltages are 3.3 Volts. 5 Volts, and 12 Volts, the capacitors on the motherboard are next in the diagnoses.
[ What was the Voltages, by the way? ]
Electrolytic Capacitors are used as Filters, and Voltage Regulators, on the motherboard.
The ones used as voltage regulators are in the Motherboard Voltage Regulator Circuit.
Part of what the motherboard voltage regulator does, is to regulate voltage for the Processor.
The Processor must have a steady, 'clean', supply of Voltage, and it MUST stay within a tight tolerance range.
Too little, or too much, and the Processor turns off. (BIOS turns it off)
{Capacitors in the motherboard voltage regulator circuit, that regulate voltage for the Processor, are in a Series circuit. If just ONE goes bad, the circuit is down }
An Electrolytic Capacitor used on motherboards, and in Power Supply's, for personal computers, is a Radial Aluminum Electrolytic Capacitor.
Radial refers to the design. With the radial design the leads, (2), both come out of the same end,
Basic construction of an Electrolytic Capacitor is;
1) An outside case (Shell) that resembles an aluminum Coca-Cola can, with no top, or bottom.
2) The top cover is a Vented Cover. Flat aluminum thin disk with a shape etched partway into it. The shape is usually an X or K.
3) The bottom cover is a Bung. A synthetic rubber disk shaped piece, that has the two leads coming through it. (Positive and Negative lead. Lead.......think stiff wire )
4) There are three strips inside the capacitor's case.
A) Conducting Strip. Also known as the Positive strip.
A thin strip of metal aluminum foil, that has the Positive lead connected to it.
B) Non-Conducting Strip. Also known as the Negative strip.
A thin strip of metal aluminum foil also, but has a non-conducting medium applied to it.
The Negative lead attaches to it.
C) A paper-like strip soaked with Electrolytic Paste.
The paper-like paste soaked strip, is laid in-between the two metal foil strips, and all three are rolled up tightly.
Computer design engineers know that Electrolytic Capacitors will eventually fail. They are the weakest link. They slowly fail because the paste is a chemical. The chemical breaks down.
For this reason, the engineers use capacitors that are rated at twice of what is needed.
As the capacitor breaks down to what is 50 percent of it's capacitance, it is still 100 percent good, as far as what is needed for that circuit.
When an Electrolytic Capacitor breaks down, it is the paste inside that is breaking down.
The paste develops a gas, (Hydrogen Gas), and the gas pushes against the seals, at the Top, and Bottom.
(Vented Cover at Top, Bung at Bottom)
The seals may then be compromised.
1) The X or K, at the top in the Vented Cover, may break open, and paste will slowly ooze out.
2) The edge around the disk shaped Vented Cover may break open, and paste may slowly ooze out.
3) The synthetic rubber disk shaped Bung at the bottom, may have one edge slightly pushed out, (Usually makes the capacitor tilt on the motherboard), and paste will ooze out.
So much paste loss, and the capacitor operates at a weakened state.
Too much paste loss, and the capacitor fails.
(Starts at 0:04)
Post in a Comment as to your findings Antony, and if the 'caps' are good, we'll go on.
Jan 08, 2012 | Packard Bell iMedia Computers & Internet
Olympus Stylus 7030 Digital Camera: we rotated some pics on the sd card, on a pc, then replaced the sd card in the caemra. Now the camera will not display them. We also rotated the photos back and tried...
Afraid not. Many cameras will not display edited images, and rotating counts as an edit. If you still have the original picture (before the first rotation) then you can copy that to the card. Otherwise you'll only be able to view the picture on a computer (or other output device, like a picture frame) and/or print it.
Jul 04, 2011 | Olympus Stylus 7030 Digital Camera
I have a stylus 600 model, if i place the memory card in the cam a message will display in the screen..."write something"....what does it mean?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
May 12, 2011 | Olympus Cameras
How do you down load pictures to the computer from a olympus sp800uz
You must install special software that came with the camera to up load pictures to a computer with the cables that came with the camera. The detail is covered in the manual of which a copy can be down loaded from
A quick method of using the SD memory card in your camera to shoot pictures on, and then removing the card from the camera, plug it into a card reader attached to your computer. You also can insert the SD card directly into your printer if that printer has "PICT-BRIDGE". That means that the printer has a card reader built in. Many newer Lap Tops have a card reader built in. You may also attach a card reader by USB connection to your computer.
In any event all of the above are covered by the manual.
Jan 23, 2011 | Olympus SP800UZ Digital Camera
This is usually caused by the SD card, and is nothing to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked. (Sometimes it looks unlocked, but its so tiny, its actually in-beteen the settings. To make sure, slide it to locked, then back to unlocked again).
If it is a damaged / "cheap" card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
Have you tried the camera with another SD card, to see if the problem persists?
Feb 27, 2010 | Olympus FE-210 Digital Camera
Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service. will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 11, 2009 | Olympus FE-190 Digital Camera
Format problems of Olympus 1Gb card with C-750UZ
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
May 05, 2009 | Olympus Camedia C-350 Digital Camera
Cameras Logo
106 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
