Question about ASUS P4S533 Motherboard
Can't boot bios
After fail to  bios update show "BISO Rom Checksum error"
FORMATIE LA COMPUTADORA Y EL CD DE LOS DRIVERS NO FUNCIONA Y NO HE PODIDO CONFIGURAR LA TARJETA DE AUDIO NI DE SONIDO, LOS NECESITO. GRATIS.
P4V533-MX
ieds7113@hotmail.com
Posted on Oct 12, 2008
2 Suggested Answers
VooDooNOFX
  • 95 Answers
SOURCE: can't boot bios
This is common after doing a BIOS upgrade. It usually means that the bios was successful, but that the motherboard is just now recognizing that it has a new bios. In other words, it's seeing that the new bios is not the same as the old one you had before, and is giving you a warning that it's changed. You can usually go into the bios, and clear all messages. This should make it go away.
Post your specific motherboard, and i'll see if I can get you more info.
Steven
Posted on Sep 16, 2008
What error is 1 short & 1 long beep on a SR5123WM?
1 long, 1 short BIOS ROM checksum error The contents of the BIOS ROM to not match the expected contents. If possible, reload the BIOS from the PAQ
Welcome to my website
Oct 05, 2014 | Computers & Internet
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
Bios rom checksum error on a compaq presario SR1365CL
This is a typical sign that the CMOS battery (on the motherboard) has failed & needs to be replaced. After replacing the CMOS battery, you will need to boot into BIOS & save CMOS settings.
Jul 13, 2011 | Computers & Internet
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
Nov 01, 2009 | HP Computers & Internet
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Can't boot bios
Steven
Sep 16, 2008 | ASUS AMD 760 MP Chipset A7M266-D...
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
ASUS P4S533 Motherboard Logo
218 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
